Show 1 reply
1. Re: "[FieldName] validate failed." in dynamic form with no validation
Mandy_Wiesener Mar 16, 2013 5:17 PM (in response to farrelldoc)Hi,
you have to use this script in the exit-event from the user input-date-field. This script is correct for a subtraction. (without error messages )
if(this.rawValue != null) { var sDate = util.scand("yyyy-mm-dd", this.rawValue); //THE SEVEN IN THE END OF THE LINE YOU CAN CHANGE WHEN YOU WISH TO ADD MORE OR LESS DAYS var NewsDate = Number(sDate) - (24*60*60*1000*7); var nDate = util.printd("dd.mm.yyyy", new Date(NewsDate)); //DatumsUhrzeitfeld2 --> YOUR TARGET FIELD --> PLEASE CHANGE THE NAME IN YOURS DatumsUhrzeitfeld2.rawValue = nDate; }I hope it's helpful for you?
Kind regards
Mandy
