we are facing an issue while configuring the external apche web server to work with coldfusion 9
Please Go though my this link will solve your problem:-
http://ashishtondon.blogspot.in/2012/05/how-to-host-more-then-one-coldfusion.html
If apache server is external please go through the link:
http://help.adobe.com/en_US/ColdFusion/9.0/Installing/WSc3ff6d0ea77859461172e0811cdec18c28-7ffd.html
You configure an external web server connection by using the Web Server Configuration Tool, which you can run through a graphical user interface (GUI) or the command line. The Windows discussions describe GUI mode, and the UNIX instructions describe command-line mode; however, you can use GUI mode in UNIX if you have access to a graphical environment.
By this way we can even host more then one CF versions on one apache server
