When I click on a Webhelp Index item that has multile entries, nothing happens. I had this problem with RH8 HTML too. I've tried turning off the Popup blocker but that doesn't solve it.
Can anyone suggest a solution to this problem?
Hi Karen,
Thank you for the workaround. Unfortunately it didn't work for IE9 browser.
Best Regards,
Paul
Hi there
I noticed this happening in the last RoboHelp class I facilitated. The participant had the same thing occur. The way we got past it was to adjust the security settings of the IE browser. Specifically, visit the Advanced tab and scroll it to the Security section. I believe what you want to enable is the option to allow active content to run as shown below.
Click the image to see a possibly larger and clearer view.
Cheers... Rick
Thanks for your reply, Rick, but this option is already selected on my IE 9 Browser.
Have you also ensured that you have disabled Mark Of The Web in the Single Source Layout recipe? I believe we also had to take that step.
Thanks again, but the Mark of the Web option was already disabled.
Did you manage to sort this out? I am having the same problem, not being able to view WebHelp index items with multiple entries, but in
Chrome and Safari using TCS3 with RH9.
If you managed to find a solution could you let me know please.
Many thanks,
Karen
Unfortunately I have not been able to sort this out. I'll post a solution if I find one.
Cheers,
Paul
Thanks for getting back to me. Let me know if I can help out as I am able to view multiple index entries with
IE9, but have RH9 not RH10.
Cheers,
Karen
Hi Paul,
One of our software developers had a look at this for me and came up with the following workaround to display multiple
index entries in both Safari and Chrome:
In whibody.htm replace this:
} else if (gbNav6) {
with this:
} else if (gbNav6 || gbChrome || gbSafari) {
Best wishes,
Karen
Hi Karen,
Best Regards,
Paul
Hi Karen,
My colleague has solved this problem for IE9 . In whibody.htm replace both instances of this:
if (gbIE55)
with this
if (false)
Many thanks for pointing us in the right direction.
Best Regards,
Paul
