Hello I recently added this problem to a old Discussion in the comments but I am not sure it was the best place for it.
I've been trying to add audio to my Flash. Everything is running smoothly except when I click on a muteToggle and playPauseToggle button that are both placed on my stage. I have instance names for both of them. These are the Errors I get in my Output.
TypeError: Error #1009: Cannot access a property or method of a null object reference.
at info.mixnwithmarissa.cakecreater::Main/togglePlayPause()[/Users/stude nt/Desktop/MM461_Lab3_mpollocktest1/info/mixnwithmarissa/cakecreater/M ain.as:153]
at info.mixnwithmarissa.cakecreater::Main/toggleMute()[/Users/student/De sktop/MM461_Lab3_mpollocktest1/info/mixnwithmarissa/cakecreater/Main.a s:138]
Also here is my code in my main.as
package info.mixnwithmarissa.cakecreater
import flash.display.MovieClip;
import flash.events.Event;
import flash.events.MouseEvent;
import flash.net.navigateToURL;
import flash.sampler.StackFrame;
import flash.net.URLRequest;
import flash.net.URLLoader;
import flash.events.IOErrorEvent;
import flash.events.ProgressEvent;
import flash.display.Loader;
import flash.media.Sound;
import flash.media.SoundChannel;
import flash.media.SoundLoaderContext;
import flash.media.SoundTransform;
/*added*/
public class Main extends MovieClip
private var musicPaused:Boolean = false;
private var musicMuted:Boolean = false;
private var musicPosition:Number = 0;
private var musicControls:MovieClip;
private var musicTrans:SoundTransform = new SoundTransform();
private var intro:MovieClip;
private var startt:MovieClip;
private var setting:MovieClip;
//private var game:MovieClip;
private var currentState:String;
private var xmlURL:URLRequest;
private var xmlLdr:URLLoader;
private var imgURL:URLRequest;
private var imgLdr:Loader;
private var swfURL:URLRequest;
private var swfLdr:Loader;
private var loaderDisplay:MovieClip;
private var transitionSound:Sound;
public var themeSound:Sound;
private var themeSoundURL:URLRequest;
public var themeChnl:SoundChannel;
public var themeLoaderContext:SoundLoaderContext;
public var xmlObj:XML;
public var globalVol:Number = 1;
private var main:MovieClip;
public function Main()
xmlURL = new URLRequest("xml/Appxml.xml");
xmlLdr = new URLLoader();
xmlLdr.addEventListener(Event.COMPLETE,onXMLLoaded);
xmlLdr.addEventListener(IOErrorEvent.IO_ERROR,onIOErro r);
xmlLdr.load(xmlURL);
muteToggle.addEventListener(MouseEvent.CLICK, toggleMute);
playPauseToggle.addEventListener(MouseEvent.CLICK, togglePlayPause);
private function onXMLLoaded(evt:Event):void
xmlObj = new XML(xmlLdr.data);
trace(xmlObj);
//trace(mainXML.theme.music.@src);
//trace("background image: "+mainXML.theme.@bg);
//trace("theme music: "+mainXML.theme.@music);
imgURL = new URLRequest(xmlObj.intro.theme.@bg);
imgLdr = new Loader();
//Note: Loader objects are display objects, so they must be added to the display list
addChild(imgLdr);
imgLdr.contentLoaderInfo.addEventListener(Event.COMPLE TE,onImgLoaded);
intro = new Intro();
this.addChild(intro);
currentState = "intro";
themeSoundURL = new URLRequest(xmlObj.intro.theme.@music);
trace("music path: "+xmlObj.intro.theme.@music);
themeSound = new Sound();
themeLoaderContext = new SoundLoaderContext(3000, false);
themeSound.addEventListener(Event.COMPLETE,soundLoaded );
themeChnl = new SoundChannel();
themeSound.load(themeSoundURL, themeLoaderContext);
themeChnl = themeSound.play();
/*var snd:Sound = new Sound();
var context:SoundLoaderContext = new SoundLoaderContext(5000);
var req:URLLoaderRequest = new URLLoader*/
private function soundLoaded(evt:Event):void{
trace("Sound Loaded!");
private function onImgLoaded(evt:Event):void
//trace("Image loaded!");
imgLdr.x = 20;
imgLdr.y = 20;
imgLdr.width = 200;
var origW:Number = imgLdr.contentLoaderInfo.width;
var origH:Number = imgLdr.contentLoaderInfo.height;
var newHeight:Number = origH * 200 / origW;
imgLdr.height = newHeight;
imgLdr.y = stage.stageHeight / 2 - imgLdr.height / 2;
private function toggleMute(evt:MouseEvent):void{
if (!musicMuted){
musicTrans.volume = 0;
main.globalVol = 0;
main.themeChnl.soundTransform = musicTrans;
muteToggle.gotoAndStop(2);
musicMuted = true;
}else{
musicTrans.volume = 1;
muteToggle.gotoAndStop(1);
musicMuted = false;
private function togglePlayPause(evt:MouseEvent):void{
if (!musicPaused){
main.themeChnl.stop();
musicPaused = true;
playPauseToggle.gotoAndStop(2);
}else{
main.themeChnl = main.themeSound.play(musicPosition);
musicPaused = false;
playPauseToggle.gotoAndStop(1);
private function onIOError(evt:IOErrorEvent):void
trace("XML loading error!!!");
public function changeState(newState:String):void
switch (currentState)
case "intro" :
removeChild(intro);
break;
case "start" :
removeChild(startt);
break;
case "setting" :
removeChild(setting);
break;
//case "game":
//game = new Game();
//removeChild(game);
//break;
switch (newState)
case "intro" :
addChild(intro);
break;
case "start" :
startt = new Startt();
addChild(startt);
break;
case "setting" :
setting = new Setting();
addChild(setting);
break;
//case "game":
//addChild(game);
//break;
currentState = newState;
//now play transition sound recently added!
transitionSound = new ButtonSound();
transitionSound.play();
Here is a screenshot of my fla
Never mind got it, it was the .main because I recently moved it from my intro.as
