The PC in question is running IE 9.0.8112.16421
Windows 7 64 bit
I have installed (and reinstalled) the latest flash player 11.2.202.235 to no avail.
I have disabled hardware acceleration
I have installed the latest graphics card drivers from the manufacturer.
When I attempt to play a video on sites like youtube, the player shows the initial frame, but then shows only the background (as if the player weren't there at all) and plays the audio only. If I move the screen up and down (using the scroll wheel) repeatedly, the player refreshes and will show a frame of the video then it goes back to the background color.
I've tested in both Firefox and Chrome and the player seems to work just fine in those browsers, so it's some sort of conflict with flash 11.2 and ie9
Currently, I have three machines that are experiencing this problem, but that number seems to be increasing. It was only two last week.
Yeah, they both appear the same. Problem is that, now, I cannot recreate the problem. I checked all the version numbers and they all are the same, but suddenly the problem has gone away. Not sure what was going on, but it seems to have corrected itself.
Great, its possible you ran into a youtube issue that they've corrected.
Chris,
I've got a similar problem, although I don't recall ever having the problem when in YouTube...only when playing videos (occasionally) on other sites.
I tried your Test 1 and Test 2 above. Test 1 had sound, but no picture. Test 2 was normal, with both picture and sound.
I'm running Flash Player 11.6.602.180, with Windows 7 SP1, and IE10.
Any advice?
Thanks.
@LAHColombia - Please check to see if you have the following Windows update installed.
KB2670838 – Platform Update for Windows 7 x64
If so, please uninstall it and try Flash Player out again. Please note, this might also require rolling IE10 back to IE9.
That did the trick, Chris.
I uninstalled KB2670838, and it automatically rolled me back to IE9 without any further action on my part.
I tried a number of problem websites, and they are all working fine.
Thanks.
Chris,
This is an FYI to your answer above. As i mentioned before, uninstalling KB2670838 - Platform update for Windows 7 x64, worked.
Then the original problem recurred. That is, i got sound with no image when playing videos, except in full screen mode, where everything worked.
I looked and found that I had received the update again, under a slightly different name: Update for Microsoft Windows (KB0670838).
As before, uninstalling the update fixed the problem. But this time, I noticed that a warning has been added to the description of KB2670838, which explains my problem:
Important Some portable computers that have a combination of Intel and AMD video cards in a hybrid configuration have drivers that are incompatible with this platform update for Windows 7 SP1 and Windows Server 2008 R2 SP1.
Microsoft goes on to list some (but not all) symptoms, and a number of known incompatibilities...but again, not all.
Ugh! Thank you for the heads up!
