Hey
I just installed CF10 STANDARD on a Windows 2003 server with IIS6. Twice actually. The first time I installed is side by side with CF7 (yeah, I know..old) and I recalled seeing TOMCAT listed in the ISAPI Filters section of the IIS website. But after I uninstalled 7, had some funky things going on and uninstalled and reinstalled CF10 by itself, I now do NOT see anything listed under the ISAPI Filters section of IIS. In reading the IIS Config document from Adobe, I see that it looks like it (and other things) should have been there, see below:
Configuring IIS:
So I'm curious whether I should punt CF off the server again and reinstall of if there are any detailed instructions for how to do these steps manually above? Adding the entry to the filter area seems straightforward but the steps following that do not seem quite so defined.
The issue I'm seeing which I think is related to this is that my website doesn't redirect to the index.cfm if it's NOT on the URL. I get access denied, so I'm thinking its that this process didn't get done correctly.
Thanks for any thoughts.
S
Are you able to broswe to the pages, after adding index.cfm at the end of the url. If yes, then it can't be problem with CFM pages. It would be related to redirection to index.cfm.
Anit Kumar
Yes, if I include the /index.cfm on the URL i can run the application fine. Login, interact with all the pages, etc. I just didn't know if the fact I don't have TOMCAT listed in the ISAPI Filter page might be indicative of a installation issue.
I have 3 sites on my server that do this, and 2 sites that work fine. Scratching my head. I can get around the issue by placing an index.html file with a javascript redirect to the fully qualified index.cfm URL and all works fine. I just do not understand why this doesn't work they way it's supposed to. All was fine before the install of CF10.
Please ensure all of these IIS features are enabled:
The Default Document list (this list will be created when the configuration is added) is mentioned in web.config file at C:\inetpub\wwwroot\. Just rename the web.config to web.config_old and restart IIS.
Anit Kumar
