1. Re: Won't burn a disc...
P1965 Mar 8, 2013 9:58 PM (in response to P1965)Just to add to the above, Before the second attempt, I shut down and restarted system.
2. Re: Won't burn a disc...
Steve Grisetti Mar 9, 2013 6:59 AM (in response to P1965)What model of camcorder is your original footage coming from and what format and resolution is it? What (under the Edit menu) are your Project Settings?
How much free, clean, defragmented space is on your C drive?
3. Re: Won't burn a disc...
John T Smith Mar 9, 2013 8:04 AM (in response to P1965)As a test, set your DVD output to a folder on your hard drive and then use the FREE http://www.imgburn.com/index.php?act=download to write the folder to disc for DVD or BluRay (send the author a PayPal donation if you like his program)
4. Re: Won't burn a disc...
P1965 Mar 9, 2013 3:28 PM (in response to John T Smith)I should note that I have made a few DVD's of this project each time I have added media with no issues to date. (burning test copy for personal critique) The only things changed prior to this last attempt was some added media of .jpg and mp3 files, basically all from the same sources and some modified and or added effects and transitions.
As for movie footage used, 5 clips are from an iphone 4s (.mov) and one from an unknown digital camera source in (.mpg) format. Again to date these files have all burned fine with the exception that I think the images could be a bit sharper.
I did try copying the project to a file, then burn to disc which worked however no menus were in it and it only plays on the PC.
PC info: WIN 7 home 64 bit, AMD 8550 tri core 2.20 GigHtz 6 G Ram Video: Radeon HD 4800 series. C: HDD @ 600G, 472G free (basically a bare system with recent defrag, prior to installing Pre Ele 11)
The majority of the project settings are at default, in that I never changed them, but here are the project settings:
(hope this is what you asked for)
GENERAL: window
Edit mode: DV NTSC (greyed out)
Timebase 29.9 frames/second (greyed out)
VIDEO:
Frame size: 720 x 480 (default)
Pixel aspect (greyed out)
Fields (greyed out)
Display Format 30 fps drop frame timecode
Title safe area: 20% x 20%
Action safe area: 10% x 10%
AUDIO:
Sample Rate: 480000 (greyed out)
Diplay Format: Audio Samples
CAPTURE window
Format; DV
VIDEO RENDERING window
File format: MICROSOFT AVI DV NTSC (greyed out)
Compression: DV NTSC (greyed out)
Optimize stills box (checked)
Thank your for the help!
S
5. Re: Won't burn a disc...
John T Smith Mar 9, 2013 4:25 PM (in response to P1965)>added media of .jpg
Pictures that are "overly" large cause video editing problems
Photo Scaling for Video http://forums.adobe.com/thread/450798
-Too Large May = Crash http://forums.adobe.com/thread/879967
-And another crash report http://forums.adobe.com/thread/973935
No, that is not what I said... you tell PreElements to create output to a FOLDER on your hard drive, and you then tell Imgburn to burn the folder to the DVD
Put a commercial movie DVD in your drive and, after you exit from the player, use Windows Explorer to look at the folder structure... that is what you want PreElements to create for you, not a file
6. Re: Won't burn a disc...
P1965 Mar 9, 2013 5:46 PM (in response to John T Smith)Guess i wasnt clear,... tried it and it can' or won't convert it. However, I was able to play the disc on a blueray player, just no menus and this still doesn't resolve the problem as it was working fine before.
7. Re: Won't burn a disc...
nealeh Mar 10, 2013 6:22 AM (in response to P1965)If you have no menus it sounds as though you are exporting the movie to a movie only format. What John is saying is to select Folder as your output from the Share> Disc dialogue.
This creates a folder on your disc that should play exactly like a DVD disc (if you don't have a software DVD player use the excellent free VLC).
If this works then the problem you have is not with the project or the PRE burning process but more likely with your burning hardware and/or blank disk media quality.
If it doesn't work then there is a PRE problem and we can proceed from there.
Cheers,
Neale
Insanity is hereditary, you get it from your children -
8. Re: Won't burn a disc...
P1965 Mar 10, 2013 5:24 PM (in response to nealeh)Using those method the project will burn to a file but whatever way it's done, the menu won't work when subsequently burned to disc. However, it works fine when run directly from the file.
That said, Pre 11 still refuses to burn discs anymore, resulting with the error I stated above.
9. Re: Won't burn a disc...
Steve Grisetti Mar 11, 2013 5:23 AM (in response to P1965)Can you Publish & Share/Computer/AVI?
(This is part of the process of troubleshooting a DVD burn issue, as we discuss in my books and in the FAQs to the right of this forum: http://forums.adobe.com/thread/415318 )
10. Re: Won't burn a disc...
nealeh Mar 11, 2013 5:29 AM (in response to P1965)If it works with a software player on the folder then PRE is producing the correct output. Not getting menus when you then burn that folder to disk suggests you are burning it as a data disk rather than a DVD Disk.
Try burning with ImgBurn using the Write files/folders to disc option. When you point it at the folder with the .VOB files and click burn it will recognise that it is a DVD disk and write the correct format. It will prompt you for a volume label.
Concerning the PRE burning component failing:
- Do you have any other disk burning software loading when your computer starts? Especially packet writing software such as Nero InCD, Drag-2-Disc, or DLA.
- What brand of blank disc are you using?
Cheers,
Neale
11. Re: Won't burn a disc...
P1965 Mar 11, 2013 6:28 AM (in response to nealeh)- Can you Publish & Share/Computer/AVI? http://forums.adobe.com/thread/415318
Have not tried this yet....not sure how, but I will read up on burning dvd topics at the link you provided,
Thank you.
I do have Nero software and will check if the settings have changed.
Disc brand is TDK - same as used in Pre 8 with success and several in Pre 11 until last attempts.
Had some issues with the "imgburn" software not working but will give it another try,
Thank you.
12. Re: Won't burn a disc...
Bill Hunt Mar 14, 2013 8:23 AM (in response to P1965)Disc brand is TDK - same as used in Pre 8 with success and several in Pre 11 until last attempts.
This might be part of the problem. Once TDK was a very respected brand of blank media. However, not that long ago, they adopted the "Memorex Business Model," where they buy the cheapest blank media available that day, then rebrand it with the "TDK" logo. What can happen is that some blank discs will be of much higher quality, than others on the same spindle. I have seen 4 different brands of blank discs in a Memorex spindle - some work well, but many do not. One of the neat little features of ImgBurn, is that it will survey your blank media, and tell you exactly who actually made it, plus the lot number.
For burning to disc, I only use Falcon Pro Media, Verbatim or Taiyo-Yuden blank media, and never anything else. To date, with well over 2000 DVD's delivered, I have never had any issues, or even one returned disc.
As for the Assets that you added, between the last time that you burned a DVD, two things need to be explored:
- The JPEG's need to be Scaled to close to the Project's Frame Size, say 1000 x 750 pixels for a DVD Project
- The MP3's could be an issue too, and I always convert any MP3's to PCM/WAV @ 48KHz 16-bit, and Import those
Good luck,
Hunt
13. Re: Won't burn a disc...
P1965 Mar 19, 2013 5:50 AM (in response to Bill Hunt)I read somewhere in one of these forums, that as the timeline grows above 10 mins, the large amount of data can be an issue so the suggestion was try converting it to an AVI and then subsequently into a new project as one file. The video created so far is about 18 mins and I did this with success as this sped up the burn process substantially, but I think some of the overall image quality was lost - not as sharp as direct from the APE program. It is great tho as you can still so some editting to the footage in the timeline.
So, is there a better file conversion than AVI that will also do this?
14. Re: Won't burn a disc...
Steve Grisetti Mar 19, 2013 5:58 AM (in response to P1965)There is no reason you should do this. You should easily be able to burn a 1 hour to 70 minute project to a disc with no problems.
But, of course, a lot depends on your computer, how fast it is, how well maintained it is, what model of camcorder your original video is coming from, how well your project is set up for that type of video, etc.
15. Re: Won't burn a disc...
P1965 Mar 19, 2013 9:11 AM (in response to Steve Grisetti)hmmm, confused - as I thought that was the suggestion above to read this thread. (http://forums.adobe.com/thread/415318)
Computer should be fast enough, 6 g RAM. I will attempt the file re-sizing as also suggested, maybe that's the issue.
GENERAL: window
VIDEO:
Fields (greyed out)
AUDIO:
CAPTURE window
Format; DV
16. Re: Won't burn a disc...
Bill Hunt Mar 19, 2013 9:46 AM (in response to P1965)That FAQ Entry lists the concept of "smaller Projects," as a workaround IF one's computer is underpowered. Yours should not be.
I can easily produce a 2 hour DVD-Video on a laptop, with far weaker specs. than your computer.
Now, Scaling overly-large Still Images will likely be very helpful. Even on a powerful computer, having to process loads of unused, unnecessary pixels, in large Still Images, will still present a resources problem. There is nothing to be gained, and much to be lost, by Importing overly-large Still Images into a DVD-Video (or even a BD) Project.
One thing that you might consider, when Scaling Still Images for use in a DVD-Video, would be to do the Save_As and use PSD, the native Photoshop format, instead of the common, and popular JPEG, which compresses the Image, with some degree of quality loss. Though the PSD's WILL be larger files, PrE can process them beautifully. As one is already giving up quality, just going to 720 x 480 (NTSC) DV, adding even a slight quality loss from JPEG compression, is something that I want to avoid.
Good luck,
Hunt
17. Re: Won't burn a disc...
P1965 Mar 19, 2013 10:13 AM (in response to Bill Hunt)Thanks very much, I have been following the thread on that subject.
One possibly dumb question: Is there a way to convert of scale, multiple jpeg imagas at once, say a folder of them, for eg. to the PSD format?
18. Re: Won't burn a disc...
John T Smith Mar 19, 2013 10:17 AM (in response to P1965)Photo Scaling for Video http://forums.adobe.com/thread/450798 has ideas
19. Re: Won't burn a disc...
P1965 Mar 19, 2013 10:22 AM (in response to John T Smith)yes, that's the one...
