Is there a walkthrough anywhere for numbered lists in RH 10, mapping to Word 2010?
Want a simple list:
1. something
2. something else
3 one more thing
Then mapping it to Word and getting the same result.
Do i create a paragraph style or a list style in RH first?
List style seems to map to Normal and nothing I can do to change this.
Para style maps to correct style name in Word (chosen from Map Non-Heading Styles) but indents. I have indent set at 0 in RH style and Word style, but list indents at 0,63
I'm going round in circles! Help! 🙂
David
Since Rh9 you can map multilevel lists in Rh to multilevel lists in Word. You can create a multilevel list and then only use the first level.
That will give you the ability to map.
Also see Lists on my site.
My question is a little different. I am using the default Styles Heading 1 Heading 2 Heading 3, etc.... plus Normal with the exception that I changed the font to Calibri.
All is working fine switching between the Headings and Normal EXCEPT when I want to insert a numbered list. As soon as I click on the number list icon the Style changes to <None> and defaults to Arial, which is not my font, but was the default for the Normal style before I udpated it.
I created a new style for Lists and can see it in the Custom tab to select it, but it hasn't stopped RH10 from defaulting to <None> and Arial. Thoughts?
That is covered in the RoboHelp Tour in the Rh9 section. You can select the list and apply Normal to correct things.
