4 Replies Latest reply: Mar 20, 2013 3:05 PM by Dan-BTP RSS
    Copy text frames between documents
    Dan-BTP Community Member
      I have two documents that have the same number of pages. I want to write a script to copy the text frames on each page in the source document to the corresponding page in the target document. Usually there's only one text frame on each page, and I want it positioned exactly the same in the target as in the source. I tried the following:
                          for (var i = 0; i < fromDoc.pages.length; i++) {
                              for (var j = 0; j < fromDoc.pages[i].textFrames.length; j++) {
                                  var fromTextFrame = fromDoc.pages[i].textFrames[j];
                                  app.select(fromTextFrame);
                                  app.copy();
                                  var toPage = toDoc.pages[i];
                                  app.select(toPage);
                                  app.paste();
      It gives me an error on the app.copy statement: "Cannot copy/cut due to invalid selection state."
      Can someone help me with the correct code? Than ks!
        • 2. Re: Copy text frames between documents
          I don't see any reply.
          • 3. Re: Copy text frames between documents
            [Ariel] Community Member
            Sorry -- it's a bug in the forum software that sometimes answers
            submitted by email don't appear. What I said is:
            You should avoid using copy(), paste() etc. -- there's almost always a
            better way of doing things.
            In this case, check out the duplicate method of a textFrame:
            TextFrame.duplicate (to:varies, by:Array of Measurement Unit (Number or
            String)): PageItem
            Adobe InDesign CS6 (8.0) Object Model
            Duplicates the TextFrame at the specified location or offset.
            to: Data Type: varies
            The location of the new TextFrame, specified in coordinates in the
            format . Can accept: Array of 2 Units, Spread, Page or Layer.
            (Optional)
            by: Data Type: Array of Measurement Unit (Number or String)
            Amount by which to offset the new TextFrame from the original
            TextFrame's position. (Optional)
            You can see that the "to" parameter of duplicate() accepts various
            things, one of which seems to be what you're looking for: page.
            So if you set myPage to be a page in a second document, presumably you
            will find that it has been duplicated to that page:
            myTextFrame.duplicate(myPage)
            Try that and see where the text frame lands up.
            If it's not in the right place, I would suggest copying the
            geometricBounds of the source textFrame to the new textFrame (there may
            be other ways of doing that). Just make sure that the ruler origin and
            measurement units in both documents are the same.
            HTH,
            Ariel
            • 4. Re: Copy text frames between documents
              That was exactly what I needed. Thanks very much!
