After installing v. 11 602, it will not play any video and terminates the program.
To help troubleshoot we'll need the following system information:
When reporting issues with video or audio, it's also helpful to get your system hardware and driver details. Instructions for finding this information can be found here:
Finally, sometimes video and audio problems are caused at a lower level and not directly related to Flash Player. I recommend trying both of the links below to see how they perform. If the problem exists with both, then Flash Player is most likely not the culprit as the HTML5 video link does not use Flash Player when playing. You can verify the use of HTML5 by right clicking the HTML5 video and looking for the words "About HTML5" at the bottom of the context menu.
Chris
Dell Inspiron 518
4 gigs RAM
32-bit
Vista Home Premium
Service Pack 2
Sea Monkey and
Internet Explorer
Adobe Flash v. 11.6.602.180
The error message has something to do with data blocking permissions.
I went back and reinstalled v. 10 and it works fine except certain videos suggest an update.
If possible, please post the entire error message (or a screenshot) if you decide to upgrade again. That might help me figure out what's going on.
Chris
So I have given you everything, are you going to solve it?
I've tried replying back to your email a few times but unfortunately the address is causing the server to return the mail as undelivered...
Can you try this version of 10.3 (it has all of the latest security updates)?
Have you tried Chrome or Firefox to see if they also exhibit this behavior? What URL’s are causing Flash Player to crash? Have you tried updating your video drivers to see if that makes a difference?
Thanks. I will be back at the computer Monday pm.
Sent from Rick's iPhone 5
I get a message from Adobe that says there is a more current version. The only option is to click the quit box.
I didn't try any other browsers.
All URL's that have a video.
mrtea@aol.com
Ah, ok. We can fix that installation error by uninstalling using the stand alone uninstaller first. You can get this at:
http://download.macromedia.com/get/flashplayer/current/support/uninstall_flash_player.exe
If you still get prompted to update when viewing videos, please let me know a specific URL that causes this message to appear. I've been trying to reproduce this problem but so far have been unsuccessful.
Chris
Any yahoo story with a video will do it. I have been using an install for v. 10. I removed that to try you
first link. So now I get what you see below. When
running V 10. I got a similar warning except
that it requested you to update. Some videos will
run on v. 10 but many need the latest version.
Hi Rick,
Can we do a quick desktop sharing session so I can see what's going on? Please email me at ccampbel@adobe.com and let me know a valid return email address.
Chris
Isent you the info.
Unfortunately, I didn't receive anything. Can you go to the forums and post the screenshot using the forum's reply toolbar (also described in my screenshot link above.)
Per your instructions.
Windows Version: 6.0.6002 x86
Windows Directory: C:\Windows
Application Data Directory: C:\Users\Rick\AppData\Roaming
Permissions: windows\system32\macromed *
Privilege 'Back up files and directories' could not be enabled. SetACL's powers are restricted. Better run SetACL with admin rights.
Privilege 'Restore files and directories' could not be enabled. SetACL's powers are restricted. Better run SetACL with admin rights.
Privilege 'Take ownership of files or other objects' could not be enabled. SetACL's powers are restricted. Better run SetACL with admin rights.
C:\Windows\system32\macromed
Owner: BUILTIN\Administrators
C:\Windows\system32\macromed\Flash
C:\Windows\system32\macromed\Flash\activex.vch
C:\Windows\system32\macromed\Flash\Flash32_11_6_602_180.ocx
DACL(not_protected+auto_inherited):
Everyone FILE_WRITE_ATTRIBUTES deny no_inheritance
NT AUTHORITY\ANONYMOUS LOGON FILE_WRITE_ATTRIBUTES deny no_inheritance
C:\Windows\system32\macromed\Flash\FlashInstall.log
C:\Windows\system32\macromed\Flash\flashplayer.xpt
C:\Windows\system32\macromed\Flash\FlashPlayerTrust
C:\Windows\system32\macromed\Flash\FlashPlayerTrust\AdobeXMPFileInfoCS5.cfg
C:\Windows\system32\macromed\Flash\FlashPlayerUpdateService.exe
C:\Windows\system32\macromed\Flash\FlashUtil10h_Plugin.exe
C:\Windows\system32\macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
C:\Windows\system32\macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
C:\Windows\system32\macromed\Flash\FlashUtil32_11_6_602_180_Plugin.exe
C:\Windows\system32\macromed\Flash\install.log
C:\Windows\system32\macromed\Flash\mms.cfg
C:\Windows\system32\macromed\Flash\NPSWF32.dll
SetACL finished successfully.
Permissions: windows syswow64\macromed *
Parsing the SD of <C:\Windows\syswow64\macromed> failed with: The system cannot find the path specified.
SetACL finished with error(s):
SetACL error message: The call to GetNamedSecurityInfo () failed
Operating system error message: The system cannot find the path specified.
Permissions: C:\Users\Rick\AppData\Roaming\Adobe\Flash Player *
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Adobe\Flash Player\AFCache
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Adobe\Flash Player\APSPrivateData2
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Adobe\Flash Player\AssetCache
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Adobe\Flash Player\AssetCache\JP438V2P
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Adobe\Flash Player\Icon Cache
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Adobe\Flash Player\NativeCache
Owner: Mrtea\Rick
Permissions: C:\Users\Rick\AppData\Roaming\Macromedia *
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#Security
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\cdn-static.liverail.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\cfiles.5min.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\cfiles.5min.com\[[IMPORT]]
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\cfiles.5min.com\[[IMPORT]]\cdata.carambo.la
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\cfiles.5min.com\[[IMPORT]]\cdata.carambo.la\Layer
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\cfiles.5min.com\[[IMPORT]]\cdata.carambo.la\Layer\client
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\cfiles.5min.com\[[IMPORT]]\cdata.carambo.la\Layer\client\CarambolaClient_v2.2.swf
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\i.123g.us
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\i.123g.us\c
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\i.123g.us\c\birth_happybirthday
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\i.123g.us\c\birth_happybirthday\card
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\i.123g.us\c\birth_happybirthday\card\103005.swf
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\macromedia.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\secure-uk.imrworldwide.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\7EFBQ4TD\vox-static.liverail.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#admin.brightcove.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#ahmestatic.fuckandcdn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#assets.newsinc.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#assets.porn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#bankofamerica.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn.innovid.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn.pornsharia.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn.tremormedia.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn1.static.keezmovies.phncdn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn1.static.pornhub.phncdn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn1.static.spankwire.phncdn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn1.static.tube8.phncdn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn1.static.youporn.phncdn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn1.thumbnails.4tube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn1.thumbnails.porntube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdn3b.static.hardsextube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdnapi.kaltura.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cdnbakmi.kaltura.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#cfiles.5min.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#chase.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#d.yimg.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#d39zux7wsehl0.cloudfront.net
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#design.yobt.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#devatube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#discovercard.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#diz.angrymovs.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#diz.bigxvideos.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#diz.madmovs.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#diz.nastymovs.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#embed.wistia.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#flash.quantserve.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#g-ecx.images-amazon.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#h2porn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#hellporno.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#hotshame.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#i.123g.us
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#img.fastcdn.me
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#l.yimg.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#m.sancdn.net
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#macromedia.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#mediax.shufuni.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#mpsnare.iesnare.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#my.screenname.aol.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#new.livejasmincdn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#pervclips.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#player.ooyala.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#s.delvenetworks.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#s.ytimg.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#secure-uk.imrworldwide.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#slytube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#smutseeker.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#static.awempire.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#static.eplayer.performgroup.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#static.ifa.camads.net
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#static.xvideos.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#sunstatic.fuckandcdn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#thenewporn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#thumbs.crakpass.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#updatetube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#us-st.xhamster.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#us.mg205.mail.yahoo.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#video.google.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#wetplace.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.assfilled.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.bravotube.net
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.careeronline.biz
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.drtuber.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.eskimotube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.fetishok.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.filthyrx.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.flirt4free.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.freepornvs.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.jizzbell.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.judgeporn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.katestube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.myxvids.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.naiadexports.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.nuvid.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.paypalobjects.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.pornicom.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.pornologo.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.pornyeah.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.proporn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.redtube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.securepaths.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.sexxxsins.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.sleazyneasy.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.thehugetits.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.thepostgame.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.winporn.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.x3xtube.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#www.xxxymovies.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#xbabe.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#yimg.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#yourlust.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin
Owner: Mrtea\Rick
C:\Users\Rick\AppData\Roaming\Macromedia\Flash Player\www.macromedia.com\bin\airappinstaller
Owner: Mrtea\Rick
Directory Listing: syswow64\macromed\flash\ *
Directory Listing: system32\macromed\flash\ *
Volume in drive C is OS
Volume Serial Number is 6437-D427
Directory of C:\Windows\system32\macromed\flash
03/12/2013 02:08 PM
BUILTIN\Administrators .
03/12/2013 02:08 PM
BUILTIN\Administrators ..
03/12/2013 01:00 PM 1,411,763 BUILTIN\Administrators activex.vch
03/12/2013 01:00 PM 14,606,552 BUILTIN\Administrators Flash32_11_6_602_180.ocx
03/12/2013 02:08 PM 91,544 BUILTIN\Administrators FlashInstall.log
03/12/2013 02:08 PM 856 BUILTIN\Administrators flashplayer.xpt
10/25/2010 07:44 AM
BUILTIN\Administrators FlashPlayerTrust
03/12/2013 01:00 PM 253,656 BUILTIN\Administrators FlashPlayerUpdateService.exe
03/12/2013 02:08 PM 231,888 BUILTIN\Administrators FlashUtil10h_Plugin.exe
03/12/2013 01:00 PM 480,984 BUILTIN\Administrators FlashUtil32_11_6_602_180_ActiveX.dll
03/12/2013 01:00 PM 706,776 BUILTIN\Administrators FlashUtil32_11_6_602_180_ActiveX.exe
03/12/2013 12:40 PM 706,776 BUILTIN\Administrators FlashUtil32_11_6_602_180_Plugin.exe
02/23/2010 11:35 AM 35,352 BUILTIN\Administrators install.log
03/12/2013 01:00 PM 47 BUILTIN\Administrators mms.cfg
03/12/2013 02:08 PM 5,612,496 BUILTIN\Administrators NPSWF32.dll
12 File(s) 24,138,690 bytes
Directory of C:\Windows\system32\macromed\flash\FlashPlayerTrust
10/25/2010 07:44 AM
10/25/2010 07:44 AM
10/25/2010 07:44 AM 74 BUILTIN\Administrators AdobeXMPFileInfoCS5.cfg
1 File(s) 74 bytes
Total Files Listed:
13 File(s) 24,138,764 bytes
5 Dir(s) 41,072,660,480 bytes free
HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer *
The system cannot find the file specified.
Registry Permissions *
HKEY_CLASSES_ROOT\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2}
Parsing the SD of <classes_root\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2}> failed with: The system cannot find the file specified.
Operating system error message: The system cannot find the file specified.
HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2}
Parsing the SD of <classes_root\Wow6432Node\CLSID\{D4304BCF-B8E9-4B35-BEA0-DC5B522670C2}> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
classes_root\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
DACL(pseudo_protected+auto_inherited):
Everyone KEY_SET_VALUEKEY_WRITEDELETE deny container_inherit+object_inherit
NT AUTHORITY\ANONYMOUS LOGON KEY_SET_VALUEKEY_WRITEDELETE deny container_inherit+object_inherit
HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
Parsing the SD of <classes_root\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A}
Parsing the SD of <classes_root\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A}> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\Wow6432Node\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A}
Parsing the SD of <classes_root\Wow6432Node\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A}> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\Interface\{2E4BB6BE-A75F-4DC0-9500-68203655A2C4}
Parsing the SD of <classes_root\Interface\{2E4BB6BE-A75F-4DC0-9500-68203655A2C4}> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\Wow6432Node\Interface\{2E4BB6BE-A75F-4DC0-9500-68203655A2C4}
Parsing the SD of <classes_root\Wow6432Node\Interface\{2E4BB6BE-A75F-4DC0-9500-68203655A2C4}> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9}
classes_root\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9}
HKEY_CLASSES_ROOT\Wow6432Node\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9}
Parsing the SD of <classes_root\Wow6432Node\TypeLib\{FAB3E735-69C7-453B-A446-B6823C6DF1C9}> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\TypeLib\{57A0E746-3863-4D20-A811-950C84F1DB9B}
classes_root\TypeLib\{57A0E746-3863-4D20-A811-950C84F1DB9B}
Owner: NT AUTHORITY\SYSTEM
HKEY_CLASSES_ROOT\Wow6432Node\TypeLib\{57A0E746-3863-4D20-A811-950C84F1DB9B}
Parsing the SD of <classes_root\Wow6432Node\TypeLib\{57A0E746-3863-4D20-A811-950C84F1DB9B}> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\.spl
classes_root\.spl
HKEY_CLASSES_ROOT\.swf
classes_root\.swf
HKEY_CLASSES_ROOT\.mfp
classes_root\.mfp
HKEY_CLASSES_ROOT\.sol
classes_root\.sol
HKEY_CLASSES_ROOT\.sor
classes_root\.sor
HKEY_CLASSES_ROOT\FlashFactory.FlashFactory
classes_root\FlashFactory.FlashFactory
HKEY_CLASSES_ROOT\FlashFactory.FlashFactory.1
classes_root\FlashFactory.FlashFactory.1
HKEY_CLASSES_ROOT\FlashProp.FlashProp
Parsing the SD of <classes_root\FlashProp.FlashProp> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\FlashProp.FlashProp.1
Parsing the SD of <classes_root\FlashProp.FlashProp.1> failed with: The system cannot find the file specified.
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash
classes_root\ShockwaveFlash.ShockwaveFlash
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.1
classes_root\ShockwaveFlash.ShockwaveFlash.1
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.3
classes_root\ShockwaveFlash.ShockwaveFlash.3
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.4
classes_root\ShockwaveFlash.ShockwaveFlash.4
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.5
classes_root\ShockwaveFlash.ShockwaveFlash.5
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.6
classes_root\ShockwaveFlash.ShockwaveFlash.6
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.7
classes_root\ShockwaveFlash.ShockwaveFlash.7
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.8
classes_root\ShockwaveFlash.ShockwaveFlash.8
classes_root\ShockwaveFlash.ShockwaveFlash.9
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.10
classes_root\ShockwaveFlash.ShockwaveFlash.10
HKEY_CLASSES_ROOT\ShockwaveFlash.ShockwaveFlash.11
classes_root\ShockwaveFlash.ShockwaveFlash.11
HKEY_CLASSES_ROOT\MacromediaFlashPaper.MacromediaFlashPaper
classes_root\MacromediaFlashPaper.MacromediaFlashPaper
HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/futuresplash
classes_root\MIME\Database\Content Type\application/futuresplash
BUILTIN\Users read allow container_inherit+object_inherit
HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-shockwave-flash
classes_root\MIME\Database\Content Type\application/x-shockwave-flash
syswow64\macromed\flash\flashinstall.log *
system32\macromed\flash\flashinstall.log *
=O====== M/10.1.53.64 2010-06-20+13-24-53.326 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\FlashPlayerUpdate.exe"
0001 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0002 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0003 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0004 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0005 00001036 Software\Mozilla\SeaMonkey\extensions/Plugins 2
0006 00001036 Software\Opera Software/Last CommandLine 2
0007 00001036 Software\Opera Software/Last CommandLine 2
0008 00001036 Software\Opera Software/Plugin Path 2
0009 00001036 Software\Opera Software/Plugin Path 2
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10h_Plugin.exe
0012 00000017 C:\Windows\system32\Macromed\Flash
=X====== M/10.1.53.64 2010-06-20+13-53-14.766 ========
?=O====== M/10.1.53.64 2010-07-04+20-50-00.293 ========
0001 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash10h.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10h_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10h_ActiveX.dll
=X====== M/10.1.53.64 2010-07-04+20-50-15.247 ========
?=O====== M/10.1.53.64 2010-08-09+14-56-46.435 ========
0000 00000010 "C:\Users\Rick\Downloads\install_flash_player.exe"
0001 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0002 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0003 00001036 Software\Mozilla\SeaMonkey\extensions/Plugins 2
0004 00001036 Software\Opera Software/Last CommandLine 2
0005 00001036 Software\Opera Software/Last CommandLine 2
0006 00001036 Software\Opera Software/Plugin Path 2
0007 00001036 Software\Opera Software/Plugin Path 2
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10h_Plugin.exe
0010 00000017 C:\Windows\system32\Macromed\Flash
=X====== M/10.1.53.64 2010-08-09+14-57-25.126 ========
?=O====== M/10.1.82.76 2010-08-20+15-35-15.356 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\EB49.dir\InstallFlashPlayer.exe" -iv 0
0001 00000013 C:\Windows\system32\Macromed\Flash\Flash10i.ocx
0002 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10i_ActiveX.exe
0003 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil10i_ActiveX.dll
=X====== M/10.1.82.76 2010-08-20+15-35-25.226 ========
?=O====== M/10.1.82.76 2010-09-15+14-29-30.201 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\3F51.dir\InstallFlashPlayer.exe" -iv 0
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10i_Plugin.exe
=X====== M/10.1.82.76 2010-09-15+14-29-54.199 ========
?=O====== M/10.1.85.3 2010-10-12+00-35-32.847 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\DC99.dir\InstallFlashPlayer.exe" -iv 0
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10k_Plugin.exe
=X====== M/10.1.85.3 2010-10-12+00-35-40.310 ========
?=O====== M/10.1.102.64 2010-12-07+16-56-05.018 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\4CF7.dir\InstallFlashPlayer.exe" -iv 0
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10l_Plugin.exe
=X====== M/10.1.102.64 2010-12-07+16-56-53.355 ========
?=O====== M/10.2.152.32 2011-03-05+17-42-43.391 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\5C14.dir\InstallFlashPlayer.exe" -iv 0
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10n_Plugin.exe
=X====== M/10.2.152.32 2011-03-05+17-42-54.688 ========
?=O====== M/11.4.402.278 2012-09-18+21-29-44.388 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\3765.dir\InstallFlashPlayer.exe" -iv 0
0001 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0002 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0003 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0004 00001036 Software\Mozilla\SeaMonkey\extensions/Plugins 2
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_4_402_278.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_278_Plugin.exe
0011 00000017 C:\Windows\system32\Macromed\Flash
0012 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0013 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_4_402_278.exe
0014 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/11.4.402.278 2012-09-18+21-30-15.536 ========
2012-9-18+22-2-12.770 1226 1062
?=O====== M/11.3.300.271 2012-09-18+22-02-09.649 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_3_300_271.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_271_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_3_300_271_ActiveX.dll
0006 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0007 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0008 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
0009 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0012 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.3.300.271 2012-09-18+22-02-14.070 ========
?=O====== M/11.4.402.278 2012-09-21+04-59-52.643 ========
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_278.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_278_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_278_ActiveX.dll
0005 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0006 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0007 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
0008 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0011 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.4.402.278 2012-09-21+05-00-02.623 ========
?=O====== M/11.4.402.278 2012-10-05+01-58-28.115 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.37c28c26789b9dc7785d815b9cb7fe03ae7e3131\install_flash_player_ax.exe" -install -iv 8
=X====== M/11.4.402.278 2012-10-05+01-58-29.034 ========
?=O====== M/11.4.402.278 2012-10-05+01-58-42.365 ========
=X====== M/11.4.402.278 2012-10-05+01-58-46.757 ========
2012-10-9+11-2-19.149 1226 1062
?=O====== M/11.4.402.287 2012-10-09+11-02-07.112 ========
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_287.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_287_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_287_ActiveX.dll
=X====== M/11.4.402.287 2012-10-09+11-02-21.872 ========
2012-10-9+12-2-30.297 1226 1062
?=O====== M/11.4.402.287 2012-10-09+12-02-23.756 ========
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_4_402_287.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_287_Plugin.exe
0013 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0014 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
0015 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_4_402_287.exe
0016 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0019 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.4.402.287 2012-10-09+12-02-31.767 ========
?=O====== M/11.5.502.110 2012-11-09+16-06-51.788 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.0df3262a9fa32464b191520af718d63de4a529f6\install_flash_player.exe" -install -iv 8
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_5_502_110.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_110_Plugin.exe
0011 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0013 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0014 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0015 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
0016 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_5_502_110.exe
0017 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0020 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.5.502.110 2012-11-09+16-06-56.015 ========
2012-12-11+22-2-20.472 1226 1062
?=O====== M/11.5.502.135 2012-12-11+22-02-10.986 ========
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_135.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.dll
0005 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
=X====== M/11.5.502.135 2012-12-11+22-02-22.010 ========
2012-12-11+23-2-38.600 1226 1062
?=O====== M/11.5.502.135 2012-12-11+23-02-34.139 ========
0009 00001015 C:\Windows\system32\Macromed\Flash\NPSWF32_11_5_502_110.dll 5
0010 00001015 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_5_502_110.exe 5
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_5_502_135.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_Plugin.exe
0013 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0014 00000017 C:\Windows\system32\Macromed\Flash
0015 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0016 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0017 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
0018 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_5_502_135.exe
0019 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0022 00001024 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.5.502.135 2012-12-11+23-02-39.886 ========
?=O====== M/11.5.502.146 2013-01-09+14-03-48.534 ========
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_146.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.dll
=X====== M/11.5.502.146 2013-01-09+14-04-06.108 ========
2013-1-9+15-3-57.275 1226 1062
?=O====== M/11.5.502.146 2013-01-09+15-03-48.242 ========
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_5_502_146.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_146_Plugin.exe
0016 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_5_502_146.exe
=X====== M/11.5.502.146 2013-01-09+15-03-58.760 ========
?=O====== M/11.5.502.149 2013-02-08+09-02-09.230 ========
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_149.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.dll
=X====== M/11.5.502.149 2013-02-08+09-02-18.204 ========
2013-2-8+10-2-15.930 1226 1062
?=O====== M/11.5.502.149 2013-02-08+10-02-12.637 ========
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_5_502_149.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_Plugin.exe
0016 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_5_502_149.exe
=X====== M/11.5.502.149 2013-02-08+10-02-17.215 ========
?=O====== M/11.6.602.168 2013-02-22+13-50-24.288 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.e10909b65ee3bf78f614936e3cffd7d25e59a4b4\install_flash_player.exe" -install -iv 8
0009 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_6_602_168.dll
0010 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_Plugin.exe
0013 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_6_602_168.exe
0014 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0015 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0016 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
=X====== M/11.6.602.168 2013-02-22+13-50-28.521 ========
?=O====== M/11.5.502.149 2013-02-22+13-55-02.702 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe" -maintain activex
0001 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe 5
0003 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe 5
0004 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.dll 5
0006 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.dll 5
0007 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0008 00001037 Software\Macromedia\FlashPlayerActiveX/ 2
0009 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0010 00001037 Software\Microsoft\Code Store Database\Distribution Units\{D27CDB6E-AE6D-11CF-96B8-444553540000}/ 2
0012 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0013 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0014 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0015 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.dll 5
0016 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_149_ActiveX.exe 5
=X====== M/11.5.502.149 2013-02-22+13-55-09.339 ========
2013-2-22+13-55-38.875 1226 1062
?=O====== M/11.6.602.168 2013-02-22+13-55-16.894 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_Plugin.exe" -maintain plugin
0001 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_Plugin.exe 5
0002 00001037 Software\Microsoft\Windows\CurrentVersion\RunOnce/FlashPlayerUpdate 2
0003 00001037 Software\Macromedia\FlashPlayerPlugin/ 2
0004 00001037 Software\Macromedia\FlashPlayer/FlashPlayerVersion 2
0005 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0007 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0008 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0009 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0010 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0011 00001037 Software\Microsoft\Windows\CurrentVersion\Control Panel\Extended Properties\System.ControlPanel.Category/C:\Windows\system32\FlashPlayerCPLApp.cpl 2
0013 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0014 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0015 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0016 00001036 Software\Mozilla\SeaMonkey\extensions/Plugins 2
0017 00001036 Software\Opera Software/Last CommandLine 2
0018 00001036 Software\Opera Software/Last CommandLine 2
0019 00001036 Software\Opera Software/Plugin Path 2
0020 00001036 Software\Opera Software/Plugin Path 2
0021 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_Plugin.exe 5
=X====== M/11.6.602.168 2013-02-22+13-55-39.973 ========
?=O====== M/11.6.602.168 2013-02-22+16-56-57.111 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.3446ba671752bb85ce458b03c411ce2b14500910\install_flash_player.exe" -install -iv 8 -au 1
0002 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0005 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0006 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0007 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0008 00001036 Software\Mozilla\SeaMonkey\extensions/Plugins 2
0009 00001036 Software\Opera Software/Last CommandLine 2
0010 00001036 Software\Opera Software/Last CommandLine 2
0011 00001036 Software\Opera Software/Plugin Path 2
0012 00001036 Software\Opera Software/Plugin Path 2
0013 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_6_602_168.dll
0014 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_Plugin.exe
0015 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0016 00000017 C:\Windows\system32\Macromed\Flash
0017 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_6_602_168.exe
0018 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
=X====== M/11.6.602.168 2013-02-22+16-56-59.485 ========
?=O====== M/11.6.602.168 2013-02-22+17-43-12.644 ========
0000 00000010 "C:\Users\Rick\Downloads\flashplayer_11_ax_debug.exe"
0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_168.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_ActiveX.dll
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0010 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0011 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
=X====== M/11.6.602.168 2013-02-22+17-43-24.263 ========
?=O====== M/11.6.602.168 2013-02-22+17-46-10.281 ========
0004 00001037 Software\Macromedia\FlashPlayer/SwfInstall 2
0006 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0007 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0009 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0010 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0011 00001036 Software\Mozilla\SeaMonkey\extensions/Plugins 2
0012 00001036 Software\Opera Software/Last CommandLine 2
0013 00001036 Software\Opera Software/Last CommandLine 2
0014 00001036 Software\Opera Software/Plugin Path 2
0015 00001036 Software\Opera Software/Plugin Path 2
0016 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_168_Plugin.exe 5
=X====== M/11.6.602.168 2013-02-22+17-46-31.902 ========
?=O====== M/10.3.183.50 2013-02-22+18-20-34.191 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\wz4f0a\fp_10.3.183.50_archive\10_3_r183_50\flashplayer_10_3r183_50_win.exe"
0003 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0004 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0005 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0009 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0011 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0012 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0014 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0015 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0016 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0017 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0018 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0019 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0020 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0021 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0022 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0023 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0024 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0025 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0026 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0027 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0028 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0029 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0030 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0031 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0032 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0033 00001036 Software\Macromedia\FlashPlayerPlugin/PlayerPath 2
0034 00001036 Software\Macromedia\FlashPlayerPlugin/Version 2
0035 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0036 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0037 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0038 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0039 00001036 Software\Mozilla\SeaMonkey\extensions/Plugins 2
0040 00001036 Software\Opera Software/Last CommandLine 2
0041 00001036 Software\Opera Software/Last CommandLine 2
0042 00001036 Software\Opera Software/Plugin Path 2
0043 00001036 Software\Opera Software/Plugin Path 2
0044 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0045 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10zk_Plugin.exe
0046 00000017 C:\Windows\system32\Macromed\Flash
0047 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0048 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0049 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
=X====== M/10.3.183.50 2013-02-22+18-21-10.852 ========
?=O====== M/11.6.602.180 2013-03-12+12-01-03.006 ========
0009 00001015 C:\Windows\system32\Macromed\Flash\NPSWF32.dll 5
0010 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_6_602_180.dll
0011 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_Plugin.exe
0012 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0013 00000017 C:\Windows\system32\Macromed\Flash
0014 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_6_602_180.exe
0018 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/11.6.602.180 2013-03-12+12-01-05.607 ========
?=O====== M/11.6.602.180 2013-03-12+12-06-18.869 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_Plugin.exe" -maintain plugin
0001 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_Plugin.exe 5
0016 00001015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_Plugin.exe 5
=X====== M/11.6.602.180 2013-03-12+12-06-27.655 ========
?=O====== M/11.6.602.180 2013-03-12+16-06-27.933 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.30b4b303e9dc1e52a13b5ca51f584cb2c8491145\install_flash_player.exe" -install -iv 8 -au 1
0013 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32_11_6_602_180.dll
0014 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_Plugin.exe
0017 00000022 C:\Windows\system32\Macromed\Flash\FlashPlayerPlugin_11_6_602_180.exe
0019 00001024 C:\Windows\system32\FlashPlayerCPLApp.cpl 183
0020 00001024 C:\Windows\system32\FlashPlayerApp.exe 183
0021 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/11.6.602.180 2013-03-12+16-06-30.481 ========
?=O====== M/11.6.602.180 2013-03-12+17-33-39.878 ========
=X====== M/11.6.602.180 2013-03-12+17-33-55.254 ========
?=O====== M/11.6.602.180 2013-03-12+17-40-19.727 ========
=X====== M/11.6.602.180 2013-03-12+17-40-26.507 ========
?=O====== M/11.6.602.171 2013-03-12+17-42-13.861 ========
0000 00000010 "C:\Users\Rick\AppData\Local\Temp\fp_pl_pfs_installer.exe"
=X====== M/11.6.602.171 2013-03-12+17-42-55.363 ========
?=O====== M/11.6.602.180 2013-03-12+17-58-17.412 ========
=X====== M/11.6.602.180 2013-03-12+17-58-23.520 ========
?=O====== M/11.6.602.180 2013-03-12+18-00-15.989 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.d03eedd4e4ea48ce57b4a7c7612c8ebe596e93aa\install_flash_player_ax.exe" -install -iv 8 -au 1
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
=X====== M/11.6.602.180 2013-03-12+18-00-19.593 ========
?=O====== M/10.1.53.64 2013-03-12+19-07-42.195 ========
0003 00001037 SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer/ 2
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player Plugin/ 2
0005 00001036 Software\Mozilla\Firefox\extensions/Plugins 2
0006 00001036 Software\Mozilla\Mozilla Firefox\extensions/Plugins 2
0007 00001036 Software\Mozilla\SeaMonkey\extensions/Plugins 2
0008 00001036 Software\Opera Software/Last CommandLine 2
0010 00001036 Software\Opera Software/Plugin Path 2
0012 00000014 C:\Windows\system32\Macromed\Flash\NPSWF32.dll
0013 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil10h_Plugin.exe
=X====== M/10.1.53.64 2013-03-12+19-08-05.902 ========
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
Owner: Mrtea\Rick
03/12/2013 02:08 PM
03/12/2013 02:08 PM
10/25/2010 07:44 AM
10/25/2010 07:44 AM
10/25/2010 07:44 AM
1 File(s) 74 bytes
Total Files Listed:
5 Dir(s) 41,072,349,184 bytes free
Windows Registry Editor Version 5.00
"Path"="C:
Windows
system32
Macromed
Flash
NPSWF32.dll"
"ProductName"="Adobe Flash Player 10.1 Plugin"
"Vendor"="Adobe Systems Incorporated"
"Description"="Adober Flashr Player 10.1 Plugin"
"Version"="10.1.53.64"
"XPTPath"="C:
Windows
system32
Macromed
Flash
flashplayer.xpt"
classes_root\.spl
classes_root\.swf
classes_root\.mfp
classes_root\.sol
classes_root\.sor
mrtea@aol.com
When you ran the flash_report.bat file, did you right click and select "run as administrator"? If not, can you delete the log and try again? Once run, please email the log file to ccampbel@adobe.com.
Chris
Yes
Odd, many of the log entries state that they don't have admin level privledges.
I still haven't received the screenshot of the error you are getting. Can you post that please?
HTML 5 video works fine.
non HTML 5 asks you to update but will play if you click on the arrow.
Would you be willing to run the following steps to generate a debug log for me? If this looks like too much work, please let me know and if you're willing we can schedule a quick desktop sharing session so I can do this on your system for you.
1. Download and extract the flash_report.zip file attached to this forum post to your desktop
2. Download “SetACL (executable version)_2.zip” from: http://bit.ly/WEppuY
2. Extract the appropriate “SetACL.exe” from either the 64 bit or 32 bit folder and place it alongside the flash_report.bat file
3. Right click flash_report.bat and select “Run as administrator”
Once run, a file named flashreport.txt will be created. Please copy/paste the contents of this file into a reply.
