I have a Mac running OS 10.6. Was notified by several apps that I needed latest version of Flash player. Have tried to download it repeatedly, have installed, uninstalled several times, rebooted and all that but apps do not recognize Flash, including U tube. Can anyone help?
What browser are you using? Safari? Could you go to this page: Flash Player Version and let me know if you see the animation and what version is reported as being installed?
Chris
I cannot see the animation or the version installed on that page
Could you please try the instructions in the last question of Mac section: http://helpx.adobe.com/flash-player/kb/flash-player-faq.html#main-pars_text_1
I think Flash Player is not enabled in Safari.
Sunil
Hi. I have done that. Nothing works. I am told it is downloaded but it doesn't work with any content, and the message after download says 0 Kilobytes downloaded. Flash player is enabled in Safari, or it has been. It was working perfectly until my computer automatically downloaded a version, which, as I understand it had security issues.
Could you please download it from the link in the following page? http://helpx. adobe.com/flash-player/kb/installation-problems-flash-player-mac.html#installer
Sunil
I can't get to page because Safari can't find "Helpx"
Tried that. Did not work.
What didn't work? The installer or link?
If it was the link, let's try this one:
http://fpdownload.macromedia.com/get/flashplayer/pdc/11.6.602.180/install_flash_player_osx.dmg
It seems to download. Then when I try to install, it shows the flash player icon and says: ' 1 item 0 K available' I install, it saysdone and a flash icon appears on my screen but flash is not available to apps. How do I get rid of all these icons? Even when I uninstall they do not go away
I tried it again. When I try to install after download it says ) 0 kilobytes available.
Chris
I am having trouble installing flashplayer on my mac (os x version 10.6.8). My browser is Safari version 5.1.8.
I can download the flashplayer installation file, but there is no application to load it up. The file does not load automatically. Adobe installation guide tells me that I do not now have a version of flashplayer installed at all. An attempt to load a video (e.g. via youtube etc) give the message 'blocked plug in'. There seems to be so many 'solution's floating around, but none that work. Do we have a solution available for Mac users, I seems to be going round in a circle.
Many thanks
Duncan
Duncan,
When you download the .dmg that I linked above, then double click to mount the file, are you not seeing a Flash Player finder window with a "Install Adobe Flash Player" application inside?
Hello
Thanks for your assistnce, have now resolved the problem
Duncan
Hello
I have the same problem. I can download the installation file from adobe, but double clicking does not load the file (no application to load it message). If you solve the problem, please let me know. I am going round in a circle.....
Duncan
