I'm creating my first Presenter 8 quiz. Each time I preview it, I encounter errors and functionality that can't be right, so I'm wondering if my settings are off, and what I should do. I've set everything up to advance manually.
When I answer a question incorrectly and then "click anywhere" to continue, I get the following error:
When you click No, the error goes away, and you have to manually advance to the next slide. Then it continues on until I answer another question incorrectly. When you click Yes, the quiz goes away. I really suspect it wasn't designed to do all that.
Thanks much!
Do you have any navigation properties set to something other than go to next slide for when the user answers the question correct/incorrect? Have you tried previewing in a web browser (the previewer can sometimes show inaccurate behavior), or publishing the presentaion and then viewing it?
Yes - I selected "Go to Slide (whatever)" so they could go back to view the slide that contains the information. Do you have to do something differently, or in addition to that, in order to get it to work?
That explains the behavior. The quiz is not an open quiz, so once you start taking it, you cannot leave the quiz boundary (between the first quiz slide and the quiz results slide) until the quiz is complete, or you will forfeit the quiz.
You can place review slides between the quiz questions, so that the viewer skips the slides if they get it right, and not if they don't.
Great, thank you. I'll try that instead!
