I'm wondering once Muse is set up and hosted with BC, can a client go in and edit -- as they can do with Word Press?
I see there are some changes in Admin panel, but I don't understand it. I've read quite a bit online but am missing this aspect.
Yes but there is an option you need to turn on in th esettings on the BC site and you wont be able to make any more changes in Muse.
Muse is a basic web builder tool, So it uploads all the site every time you mkae a change.
IF you want to build a more rich and controlled site using the BC CMS you should look to build the site using coding software such as Dreamweaver or other applications like Coda (mac) or Sublime Text 2 etc.
Hi Liam, thanks!
Does that mean if I use DW the client will be able to make changes in BC Admin panel -- and I can also jump back in with DW and update at a later time?
I do use DW, as a designer I find the earleir DW versions were easier so I find myself back and forth between MU and DW.
Hi Anita
Yes, your client would be able to access admin section of the site and make changes.
You can create site from Muse or DW , after publishing the site , adding the users as admin to the site will allow them to login to BC backend and make changes.
You can update your site from Muse or DW while working on the site to make changes.
Sanjit
Sanjit, that is not exactly true as you should know with regards to Muse. Muse does not work quite the same.
Hey Liam
I was referring to adding users at BC end and allowing admin access , you are correct as we need to enable the setting under my details.
If that is the case then admin user who has access to Muse will not be able to update the site.
Sanjit
