i've down loaded flashplayer several times. the basic program appears but the plugin does not. in th pocess i've uninstalled the program a few times. what else can i do to see videos?
What operating system and browser are you using? When you go to this page, Flash Player Version, do you see the animation or version number displayed?
Mac OS X, Ver 10.6.8
On that page both blocks are blank
Safari.
Assuming you are using Safari, can you please verify that "enable plugins" is checked in the security tab of Safari's preferences dialog? If so, please go to Safari's help menu and select Installed plugins. Once the page is displayed, copy/paste the contents in a reply.
Java Applet Plug-in
Displays Java applet content, or a placeholder if Java is not installed. — from file “JavaAppletPlugin.plugin”.
application/x-java-applet | Basic Java Applets | javaapplet |
application/x-java-applet;jpi-version=1.6.0_43 | Java applet | |
application/x-java-applet;version=1.1 | Java applet | |
application/x-java-applet;version=1.1.1 | Java applet | |
application/x-java-applet;version=1.1.2 | Java applet | |
application/x-java-applet;version=1.1.3 | Java applet | |
application/x-java-applet;version=1.2 | Java applet | |
application/x-java-applet;version=1.2.1 | Java applet | |
application/x-java-applet;version=1.2.2 | Java applet | |
application/x-java-applet;version=1.3 | Java applet | |
application/x-java-applet;version=1.3.1 | Java applet | |
application/x-java-applet;version=1.4 | Java applet | |
application/x-java-applet;version=1.4.2 | Java applet | |
application/x-java-applet;version=1.5 | Java applet | |
application/x-java-applet;version=1.6 | Java applet | |
application/x-java-vm | Java applet | |
application/x-java-vm-npruntime | Java applet |
QuickTime Plug-in 7.6.6
The QuickTime Plugin allows you to view a wide variety of multimedia content in web pages. For more information, visit the QuickTime Web site. — from file “QuickTime Plugin.plugin”.
application/sdp | SDP stream descriptor | sdp |
application/x-mpeg | AMC media | amc |
application/x-rtsp | RTSP stream descriptor | rtsp,rts |
application/x-sdp | SDP stream descriptor | sdp |
audio/3gpp | 3GPP media | 3gp,3gpp |
audio/3gpp2 | 3GPP2 media | 3g2,3gp2 |
audio/aac | AAC audio | aac,adts |
audio/ac3 | AC3 audio | ac3 |
audio/aiff | AIFF audio | aiff,aif,aifc,cdda |
audio/amr | AMR audio | amr |
audio/basic | uLaw/AU audio | au,snd,ulw |
audio/mid | MIDI | mid,midi,smf,kar |
audio/midi | MIDI | mid,midi,smf,kar |
audio/mp3 | MP3 audio | mp3,swa |
audio/mp4 | MPEG-4 media | mp4 |
audio/mpeg | MPEG audio | mpeg,mpg,m1s,m1a,mp2,mpm,mpa,m2a,mp3,swa |
audio/mpeg3 | MP3 audio | mp3,swa |
audio/vnd.qcelp | QUALCOMM PureVoice audio | qcp,qcp |
audio/wav | WAVE audio | wav,bwf |
audio/x-aac | AAC audio | aac,adts |
audio/x-ac3 | AC3 audio | ac3 |
audio/x-aiff | AIFF audio | aiff,aif,aifc,cdda |
audio/x-caf | CAF audio | caf |
audio/x-gsm | GSM audio | gsm |
audio/x-m4a | AAC audio | m4a |
audio/x-m4b | AAC audio book | m4b |
audio/x-m4p | AAC audio (protected) | m4p |
audio/x-midi | MIDI | mid,midi,smf,kar |
audio/x-mp3 | MP3 audio | mp3,swa |
audio/x-mpeg | MPEG audio | mpeg,mpg,m1s,m1a,mp2,mpm,mpa,m2a,mp3,swa |
audio/x-mpeg3 | MP3 audio | mp3,swa |
audio/x-wav | WAVE audio | wav,bwf |
image/jp2 | JPEG2000 image | jp2 |
image/jpeg2000 | JPEG2000 image | jp2 |
image/jpeg2000-image | JPEG2000 image | jp2 |
image/pict | PICT image | pict,pic,pct |
image/png | PNG image | png |
image/tiff | TIFF image | tif,tiff |
image/x-bmp | BMP image | bmp,dib |
image/x-jpeg2000-image | JPEG2000 image | jp2 |
image/x-macpaint | MacPaint image | pntg,pnt,mac |
image/x-pict | PICT image | pict,pic,pct |
image/x-png | PNG image | png |
image/x-quicktime | QuickTime image | qtif,qti |
image/x-sgi | SGI image | sgi,rgb |
image/x-targa | TGA image | targa,tga |
image/x-tiff | TIFF image | tif,tiff |
video/3gpp | 3GPP media | 3gp,3gpp |
video/3gpp2 | 3GPP2 media | 3g2,3gp2 |
video/avi | Video For Windows (AVI) | avi,vfw |
video/flc | AutoDesk Animator (FLC) | flc,fli,cel |
video/mp4 | MPEG-4 media | mp4 |
video/mpeg | MPEG media | mpeg,mpg,m1s,m1v,m1a,m75,m15,mp2,mpm,mpv,mpa |
video/msvideo | Video For Windows (AVI) | avi,vfw |
video/quicktime | QuickTime Movie | mov,qt,mqv |
video/sd-video | SD video | sdv |
video/x-m4v | Video (protected) | m4v |
video/x-mpeg | MPEG media | mpeg,mpg,m1s,m1v,m1a,m75,m15,mp2,mpm,mpv,mpa |
video/x-msvideo | Video For Windows (AVI) | avi,vfw |
WebKit built-in PDF
— from file “”.
here it is but i don't see flash player in there.
I don't see it either, let's try installing using this file:
http://fpdownload.macromedia.com/get/flashplayer/pdc/11.6.602.180/install_flash_player_osx.dmg
i must be doing something wrong. when i click on the link, i get a new page with a blank address line. when i cut/paste i get "page not found"
You should see a download start when you click that link. Check your downloads folder for a file named "install_flash_player_osx.dmg".
not there.
got to go for now. be back in a few hours.
thanks
sorry, i'm back. forgot to send the last post.
Can you verify that you're doing the steps outlined in this video:
didn't see video. but doing all steps in directions without results.
trying butgetting blank screen for video
video no longer blank but print is larger than video screen so i can't say if i did all steps
note that when i download, i don't get a "save" choice.
