After installing Google Chrome with Adobe Flash Player,sound on Flash Player (not sure of the source) bleeds thru when Flash Player is not in use. Problem goes away when Flash Player is uninstalled and returnes when Flash Player is re installed. Windows 7 OS on a Dell XPS 17.
I'd run a malware scan to make sure you aren't being forced this content (http://www.malwarebytes.org/) I haven't heard this reported and the constant boxes requesting to reinstall sound suspicious.
I'm not sure I understand what you mean by the sound bleeding through. Do you have tabs opened in Chrome that could be playing audio?
Hi Chris,
Thank you for your reply. The sound I get is difficult to explain. The
content seems to be some kind of commercial or talk show. one sound track
is on ADD. It appears independent of the tabs open including none open. As
I mentioned in my first post this condition is dependant on if Adobe Flash
Player is installed on the computer. As a side note, when the Adobe
Flash Player is uninsulated I continually get a box requesting to reinstall
the program. When I do, the problem returns.
I agree with your suspicions. Will run the malwarebytes. Will get back to
you with results.
Malwarebyts detected 32 infections.Interesting, my malware program did not
detect them. Removed them. It appears to have solved the problem. Will
advise. Thank you for the help.
