I've tried almost everything that this forum suggested but Flash player just won't install. Here is my story. A a month or so ago, flash just stopped working on IE 9. I uninstalled but now I'm unable to even download it. When click on download now, This is what it displays and nothing ever happens. I reset my IE settings. Under tools, Safety, ActiveX Filtering is uncheck. Under Manage Add-ons I just don't see the Active x for flash add-on I'm assuming this is because flash is not installed. I even did the whole Subinacl and reset.bat file but still I'm unable to download flash. Currently Flash works fine on Firefox which is what I'm using right now. I don't have any Flash cookie cop or any other software installed that blocks flash. Am I missing something? I really do not want to reinstall windows. Is there an other way to fix this problem? I am using 32-bit IE and not 64.
thank you.
Chris,
This issue was solved finally. I figured it out eventually. Some how the registry was locked by something called FlashBroker.
As you can see the logs below. The way I fixed this was by using ComboFix. I just ran the file and it cleaned out the system and fixed all registry problems. I'm now able to see flash on IE. I'm sure someone will eventually run into this issue again so it'll be helpful for you and others to know how to fix it.
Thank you for all your help.
Samad
--------------------- LOC
...Copy link to clipboard
Please try installing from the appropriate stand alone Windows installers located here:
Installation Problems - Flash Player - Windows
Chris
I just installed it and it seems to have installed just fine but my vidoes are still not playing when i goto youtube, it just stays on a black screen and I also cannot see the thumbnails of the videos.
Do you see the animation and version number displayed on this page?
No I don't. It's just Blank on IE.
Ok, lets make sure things are enabled properly. Please walk through the steps in the two faq's below.
My Shockwave Flash Object shows under Run without permissions and not under currently loaded add-ons.
We could be running into an issue with a recent Windows update for Win 7 x64.
Could you check to see if you have the following Windows update installed?
KB2670838 – Platform Update for Windows 7 x64
If so, I’d first recommend you update your video driver. If that doesn’t fix the problem, please uninstall the KB update and try again.
Chris
yes, I did have this update installed. I updated my video drivers last night so I know that is not the issue but I went ahead and uninstalled the updated and restarted my computer. Still the same problem. I'm unable to install flash player from the website and it's still showing Shockwave Flash Object shows under Run without permissions and not under currently loaded add-ons.
That does seem odd that it's not listed under currently loaded addons. Did you verify that active x filtering was disabled? Baring that, the next thing I'd suggest is a clean install of Flash Player, then a reset of IE.
Yes, I verified and active x filtering is unchecked. I followed the steps and completely uninstalled Flash and reset my IE settings but still I'm unable to install flash on IE. Currenly I have no flash installed at all. Not even on Firefox. What do you think? windows format at this point?
I don't think we'll have to do a format just yet. What's happening when you try and install? Does it say it's finishing properly? What files do you have in these two folders:
c:\windows\system32\macromed\flash
c:\windows\syswow64\macromed\flash
When I goto http://get.adobe.com/flashplayer/ on IE and click on Download now, Nothing happens. I don't get the Active X to popup but I went to this site and downloaded the IE Active X manually http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html and was able to install it but now again the active x is showing under Run without permission and not under currently loaded add-ons.
Here is what installed.
It appears that you have the ActiveX version of Flash installed properly. Now the question is why isn't IE loading it. Are you running any antivirus/security software?
You can install the version for Firefox here:
http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player.exe
I'm only running Malwarebyte Pro verison. I did install firefox add-on successfully an its working.
Malwarebytes should be fine, I run the pro version myself. It's very odd that IE isn't working... If you're interested, I'd be willing to do a short desktop sharing session with you to see if I can figure out what's going on. You've run through most of the steps I'd take, but we might get lucky. Shoot me an email (ccampbel@adobe.com) if this sounds interesting.
Chris,
Samad
--------------------- LOCKED REGISTRY KEYS ---------------------
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil64_11_6_602_180_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\LocalServer32]
@="c:\\Windows\\system32\\Macromed\\Flash\\FlashUtil64_11_6_602_180_ActiveX.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\TypeLib]
@="{FAB3E735-69C7-453B-A446-B6823C6DF1C9}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}]
@="IFlashBroker5"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\ProxyStubClsid32]
@="{00020424-0000-0000-C000-000000000046}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}]
@="FlashBroker"
"LocalizedString"="@c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil32_11_6_602_180_ActiveX.exe,-101"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\Elevation]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\LocalServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\FlashUtil32_11_6_602_180_ActiveX.exe"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{73C9DFA0-750D-11E1-B0C4-0800200C9A66}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}]
@="Shockwave Flash Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\InprocServer32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash32_11_6_602_180.ocx"
"ThreadingModel"="Apartment"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\MiscStatus]
@="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ProgID]
@="ShockwaveFlash.ShockwaveFlash.11"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
@="c:\\Windows\\SysWOW64\\Macromed\\Flash\\Flash32_11_6_602_180.ocx, 1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\TypeLib]
@="{D27CDB6B-AE6D-11cf-96B8-444553540000}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="ShockwaveFlash.ShockwaveFlash"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}]
@="Macromedia Flash Factory Object"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\InprocServer32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ProgID]
@="FlashFactory.FlashFactory.1"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\ToolboxBitmap32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\TypeLib]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\Version]
@="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000}\VersionIndependentProgID]
@="FlashFactory.FlashFactory"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}]
@="IFlashBroker5"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Wow6432Node\Interface\{6AE38AE0-750C-11E1-B0C4-0800200C9A66}\TypeLib]
"Version"="1.0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Office\Common\Smart Tag\Actions\{B7EFF951-E52F-45CC-9EF7-57124F2177CC}]
@Denied: (A) (Everyone)
"Solution"="{15727DE6-F92D-4E46-ACB4-0E2C58B31A18}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Schema Library\ActionsPane3]
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Schema Library\ActionsPane3\0]
"Key"="ActionsPane3"
"Location"="c:\\Program Files (x86)\\Common Files\\Microsoft Shared\\VSTO\\ActionsPane3.xsd"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows CE Services]
"SymbolicLinkValue"=hex(6):5c,00,72,00,65,00,67,00,69,00,73,00,74,00,72,00,79,
00,5c,00,4d,00,41,00,43,00,48,00,49,00,4e,00,45,00,5c,00,53,00,4f,00,46,00,\
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\PCW\Security]
@Denied: (Full) (Everyone)
Interesting, and you had tried installing immediately after rebooting and that still didn't work? Going to forward this on to the install team for their review but if you get a chance could you also post the contents of your flashinstall log file?
Where do I find the Flash Player installation log on Windows?
Either way, very happy you were able to get this resolved!
Nothing worked!!! I've tried everything you mentioned and a lot of other people mentioned different solutions but nothing worked! I was really frusrated but I ran into a different issue which lead me to scan using Combo Fix and that did the trick . Here are the flashlogs.
=O====== M/11.6.602.180 2013-03-26+20-37-05.884 ========
0000
0001 00000010 "C:\Users\Admin\AppData\Local\Temp\{1B22421C-C39A-4C27-BBCD-AEF5633A26F2}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_6_602_180.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
=X====== M/11.6.602.180 2013-03-26+20-37-06.713 ========
=O====== M/11.6.602.180 2013-03-26+20-49-02.580 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{DB01B84A-E095-4551-BD13-B8EDBB639C9B}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_6_602_180.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_6_602_180_Plugin.exe
0013 00000024 C:\Windows\system32\Macromed\Flash\plugin.vch
0014 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
=X====== M/11.6.602.180 2013-03-26+20-49-03.130 ========
=O====== M/11.7.700.169 2013-04-22+23-42-13.654 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.7.700.169 2013-04-22+23-42-13.691 ========
=O====== M/11.7.700.169 2013-04-22+23-42-12.968 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{3466307A-99A7-47D7-B7C0-CCF1C4E4C577}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 4294967295
0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0002
0003
0004 00000018
0005
0006
0007 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_7_700_169.ocx
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.exe
0009 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_7_700_169_ActiveX.dll
0010 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0011 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0012 00000012
=X====== M/11.7.700.169 2013-04-22+23-42-13.803 ========
