I have just installed IE10. However i try to run video and it advises i need to update flash player. I go to adobe, update flash player and advised successfully installed. I try to run video again and get the same message. I uninstalled previous versions and reported. Still get same error message but installation always successful! I am using windows 7 on 32/64bit. system upto date. I had the same fault with IE 9 but i kept uninstalling and going back to IE8. However a little fed up with doing this.
Any ideas????
I suspect you have Flash Player installed properly and something else is failing. When you go to this page, do you see the following?
http://www.bobbyvandersluis.com/swfobject/testsuite_2_2/test_dynamic_multiple.html
What version is reported when you go to this page?
Chris
