I'm trying to download Flash Player on OS 10.6.8, but all that will download is the installer. When I click on he installer, it simply downloads the installer again. I've gone through all the suggestions on the Adobe site for this problem.
You'll want to look for Flash Player in /Library/Internet Plug-ins/
You can ignore the folder in your Applications folder.
As long as you followed me through the installation steps, you should be good. When I opened the /Library/Internet Plug-ins folder I was just illustrating were the files were installed to.
Assuming you are on Safari, can you please verify that "enable plug-ins" is checked in the security tab of Safari's preferences dialog?
Can you try installing from this file?
http://fpdownload.macromedia.com/get/flashplayer/pdc/11.6.602.180/install_flash_player_osx.dmg
I got the same result: A small window appears, indicating that the file was downloaded. I click on that and I get another file that says to Install Flash Player. I click on that and an icon appears on my hard drive; the icon indicates that it's the same installer as before. So I click on that, and I get a file that says it's the installer. It's going in circles. Awhile back I did get in my applications folder a file labeled "Flash Player.plugin" but clicking on that brings no result.
In my applications folder I now have five icons labeled "Flash Player," all of which simply tell me to Install FP. I also have in the folder four docs labeled "Install Adobe Flash Player.app" but none of them will install FP.
I have had an older version of FP working, but when I received notice that I needed to upgrade, I tried to do that. I also took the advice on the Adobe site to use the FP Install Manager to delete that old version. The deletion worked fine; the installation of the upgrade doesn't work.
Are you following the same steps that I do in this video?
Since I don't have Flash Player, I can't view a video, of course. (I tried, though, since I'm an optimist.)
I was able to see the video in miniature; when I went to full screen, the screen went blank. Nevertheless, I see that I've followed your (standard) instructions to download Flash Player, but I lost you when you opened up Library. The only Library that I have in Applications holds fonts. Also, in my Applications folder I do have a Flash Player folder under Adobe; the problem is that the only thing in the Flash Player folder is a folder with "Addins."
Thanks for hanging in there on this, Chris. The "enable plug-ins" in Safari was the problem. Many thanks.
The link doesn't do anything other than what happens when I try to download Flash Player from the Adobe Web site: A file downloads; I drag it to my desktop (MacBook Pro), and click on it; a file downloads, except it's simply an app that tells me to download Flash Player (Install Adobe Flash Player.app, which appears on both my desktop and in my Applications folder).
