dodo_lin wrote:
> Our reporting tool cannot interpret Cyrillic fonts
(correctly) saved by an
nothing to do w/the fonts.
> application that was developed in ColdFusion 4. The Cold
Fusion4 application
> would disply them correctly, but the character look very
different saved in
> database.
you give no details but i guess you saved your data using
some codepage encoding
& now that cf supports unicode it's all garbage.
> convert those character to something can be read by
other products, too. How
> can we do that? I hope we would not need to convert data
manually.
no need to re-type everything, if you're sure cf4 outputs the
data correctly,
the cheapest way is to create a page on the cf4 server that
simply dumps out the
data in a format that your db can parse. then either copy
that to a text file &
use your db tools to import it as unicode or make a cfhttp
call from your cfmx
server to the cf4 server & parse & insert the data
into your db using cfmx.
