1. Re: Adobe Application Manager Stopped working
Mylenium Feb 9, 2013 4:21 AM (in response to malcolangelo)Download the latest version of AAM here and install it:
Adobe - Adobe Application Manager : For Windows
Mylenium
2. Re: Adobe Application Manager Stopped working
malcolangelo Feb 9, 2013 4:34 PM (in response to Mylenium)Hi Mylenium,
Tried that and same result “Download Error”, Download error. Press retry to try again or contact Customer support. May have to try phone support tomorrow. This has been going on for a week trying various things so as a last resort i did the total uninstall and my fears were realised, no app or access. I tried chat last week and got put over to tech support for no response. Thanks for trying to help though.
3. Re: Adobe Application Manager Stopped working
malcolangelo Mar 27, 2013 3:18 AM (in response to malcolangelo)Back to this problem,
After some time for no reason AAM decided to work again, can't remeber quite when now as have used a Windows Vista, Wndows 7 and windows 8 laptops I have acces too which all seem to work fine however they are not my computers and would like to use my windows XP desktop for the majority of my apps and unfortunately even though my AAM started working again as in it comes up and shows updates the updates do not work and the message says, "There was an error installing this update. Please try agaiin later or contact customer support (U44M1I216)".
Previously I reloaded all apps as trials and then licensed with my Adobe ID.
4. Re: Adobe Application Manager Stopped working
Jeff A Wright Mar 27, 2013 9:00 AM (in response to malcolangelo)The U44M1I216 error indicates that the update did not apply correctly. Please see Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html for information on how to review the install logs for the update. You should be able to determine the exact cause of failure by looking within the log files.
5. Re: Adobe Application Manager Stopped working
malcolangelo Mar 27, 2013 4:45 PM (in response to Jeff A Wright)Hi Jeff,
Cannot find a summary section of the two logs of the apps I have just tried to update today, however I did a, find "error", and the following showed up;
Indesign, (none are todays date though)
02/09/13 19:13:32:078 | [ERROR] | | OOBE | DE | | | | 3356 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\InDesign\Version 8.0\en_US\Extensions". Error 145 The directory is not empty.(Seq 227)
02/09/13 19:13:32:078 | [WARN] | | OOBE | DE | | | | 3356 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 227)
02/09/13 19:13:32:078 | [ERROR] | | OOBE | DE | | | | 3356 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\InDesign\Version 8.0\en_US". Error 145 The directory is not empty.(Seq 228)
02/09/13 19:13:32:078 | [WARN] | | OOBE | DE | | | | 3356 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 228)
02/09/13 19:13:32:078 | [ERROR] | | OOBE | DE | | | | 3356 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\InDesign\Version 8.0". Error 145 The directory is not empty.(Seq 229)
02/09/13 19:13:36:062 | [ERROR] | | OOBE | DE | | | | 272 | DF037: Unable to delete directory "C:\Documents and Settings\Reception\Application Data\Adobe\Extension Manager CS6\Mxi Flag". Error 145 The directory is not empty.(Seq 13)
02/09/13 19:15:05:312 | [WARN] | | OOBE | DE | | | | 272 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 9543)
02/09/13 19:15:05:328 | [WARN] | | OOBE | DE | | | | 272 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 9545)
02/09/13 19:17:17:906 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Program Files\Common Files\Adobe\ssc\AMT". Error 145 The directory is not empty.(Seq 1)
02/09/13 19:17:17:906 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 1)
02/09/13 19:17:17:906 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Program Files\Common Files\Adobe\ssc". Error 145 The directory is not empty.(Seq 2)
02/09/13 19:17:17:906 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 2)
02/09/13 19:17:17:906 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Program Files\Common Files\Adobe\PSE10STIInstaller\Adobe\AdobePatchFiles". Error 145 The directory is not empty.(Seq 3)
02/09/13 19:17:17:906 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 3)
02/09/13 19:17:17:906 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Program Files\Common Files\Adobe\PSE10STIInstaller\Adobe". Error 145 The directory is not empty.(Seq 4)
02/09/13 19:17:17:906 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 4)
02/09/13 19:17:17:906 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Program Files\Adobe\Adobe\AdobePatchFiles". Error 145 The directory is not empty.(Seq 5)
02/09/13 19:17:17:906 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 5)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Program Files\Adobe\Adobe". Error 145 The directory is not empty.(Seq 6)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 6)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\Reception\Application Data\Adobe\Extension Manager CS6\Mxi Flag". Error 145 The directory is not empty.(Seq 7)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 7)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\InDesign\Version 8.0\en_US\Extensions". Error 145 The directory is not empty.(Seq 8)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 8)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\InDesign\Version 8.0\en_US". Error 145 The directory is not empty.(Seq 9)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 9)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\InDesign\Version 8.0". Error 145 The directory is not empty.(Seq 10)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 10)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw\LensProfiles\1.0\Nikon". Error 145 The directory is not empty.(Seq 11)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 11)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw\LensProfiles\1.0". Error 145 The directory is not empty.(Seq 12)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 12)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw\LensProfiles". Error 145 The directory is not empty.(Seq 13)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 13)
02/09/13 19:17:17:921 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw\CameraProfiles\Camera". Error 145 The directory is not empty.(Seq 14)
02/09/13 19:17:17:921 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 14)
02/09/13 19:17:17:937 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw\CameraProfiles\Adobe Standard". Error 145 The directory is not empty.(Seq 15)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 15)
02/09/13 19:17:17:937 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw\CameraProfiles". Error 145 The directory is not empty.(Seq 16)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 16)
02/09/13 19:17:17:937 | [ERROR] | | OOBE | DE | | | | 2820 | DF037: Unable to delete directory "C:\Documents and Settings\All Users\Application Data\Adobe\CameraRaw". Error 145 The directory is not empty.(Seq 17)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: Command ARKDeleteDirectoryCommand failed.(Seq 17)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 18)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 19)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 20)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 21)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 22)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 23)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 24)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 25)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 26)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 27)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 28)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 29)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 30)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 31)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 32)
02/09/13 19:17:17:937 | [WARN] | | OOBE | DE | | | | 2820 | DW063: ARKCmdFS.dll:failed for command RegistryDeleteV2 - error: 0(Seq 33)
02/09/13 19:17:43:531 | [INFO] | | OOBE | DE | | | | 1480 | Exit Code: 0 - No error.
Fireworks(also none at todays dates)
02/14/13 18:39:41:828 | [ERROR] | | OOBE | DE | | | | 5636 | DF023: Unable to delete backup file at "C:\adobeTemp\backup\adobetmp10671713" Error 5 Access is denied.(Seq 50)
02/14/13 18:39:41:828 | [ERROR] | | OOBE | DE | | | | 5636 | DW063: Error committing command ARKDeleteFileCommand(Seq 50)
02/14/13 18:41:20:765 | [INFO] | | OOBE | DE | | | | 2276 | Exit Code: 0 - No error.
Thes are all previos dtaes I have tried to update I presume. Should I just delete the data in the specified directories for indesign? Don't know what the fireworks erros mean!!
6. Re: Adobe Application Manager Stopped working
Jeff A Wright Mar 27, 2013 4:57 PM (in response to malcolangelo)The DW063 error indicates that you have a file permission issue with the indicated directories. I would recommend going to a parent directory adjusting the file permissions and applying the permission change to all child objects. You can find details on how to adjust your file permissions at Error "Exit 6" or "Exit 7" | Install log | Read, write, system file errors | CS5, CS5.5 - http://helpx.adobe.com/creative-suite/kb/error-exit-6-exit-7.html.
7. Re: Adobe Application Manager Stopped working
malcolangelo Mar 27, 2013 5:13 PM (in response to Jeff A Wright)Hi yet again,
I will try that all a bit new to me though, But thanks.
Malcolm
8. Re: Adobe Application Manager Stopped working
malcolangelo Mar 27, 2013 6:36 PM (in response to Jeff A Wright)Hi Jeff,
No succes unfortunately, still the same error. What about the fact that the log does not seem to be updating to todays date?
Becoming a little frustrated.
9. Re: Adobe Application Manager Stopped working
Jeff A Wright Mar 28, 2013 8:43 AM (in response to malcolangelo)The log files are appended so you would want to search from the bottom of the document up to find the updated logs.
You may also want to try creating a new local administrator account and see if the file permissions are compromised under the new account.
10. Re: Adobe Application Manager Stopped working
malcolangelo Mar 31, 2013 10:51 PM (in response to Jeff A Wright)The logs only show the creation date throughout the log on rhe left side nothing relating to the dates I have tried to update the application.I would expect the 27th of March yo show up if anything was happening to the log. I will try the new administrator.
11. Re: Adobe Application Manager Stopped working
malcolangelo Mar 31, 2013 11:54 PM (in response to malcolangelo)Tried new admimisrtrator account but then same error as before.
12. Re: Adobe Application Manager Stopped working
Jeff A Wright Apr 8, 2013 8:13 AM (in response to malcolangelo)Malcolangelo if you are facing problems adjusting your file permissions then please contact our support team. For the best assistance, I recommend our chat support at http://adobe.ly/yxj0t6. Our chat representatives can provide a personalized experience to resolve the issue you have described.
13. Re: Adobe Application Manager Stopped working
msaprild Sep 10, 2014 9:16 PM (in response to Mylenium)I was having the same problem and this link did it for me. Thanks!
