Still trying to test the software, and here's a timeline of
my experiences this morning:
First, I dbl-clicked on my .xpj file, and RH6 opened, but it
said the .cpd file was corrupted. I should delete it, and re-open
the project, which I did.
After that point, RH6 crashes each time I try to start it. I
keep deleting the .cpd file, and the same thing keeps happening. In
this case, however, there is no .cpd-related error message. It just
says that RH needs to stop.
Finally, I ended up with an Application Error
(CiceroUIWndFrame RoboHTML.exe): The instruction at "0x0326b59a"
referenced memory at "0x03a00950". The memory could not be "read".
Click on OK to terminate the program.
I am not sure if this is a RH error, or if it's the laptop
that I'm using for the trial, since my company will not allow me to
install it on my normal work computer, which has RH5. They don't
want to take the chance.
Can anyone help identify the cause of this problem so I can
go on with my trial. Oddly, I was using it last week, accidentally
operating directly off the thumb drive that I used to bring the
files over (talk about slow!), and, while I had other problems, I
did not crash RoboHelp.
Carol
