1 10 11 12 13 14 Previous Next 660 Replies Latest reply: Jan 28, 2014 11:35 AM by bellevue scott Go to original post RSS
      • 440. Re: Photoshop CS6 does not save icon on Macintosh
        William_Donelson Community Member
        I also have never had any problems with icons before CS6...
        Are "Windows Thumbnails" on by default in CS6 ? I know they were off in CS5.
        Perhaps that is a clue?
        • 441. Re: Photoshop CS6 does not save icon on Macintosh
          Was DYP Community Member
          I have tried turning off "Windows Thumbnail". It doen't help, the corruption will eventually return. Only thing that works is to turn all icon creation off in PS6. Let the OS generate icons and you will have no more problems with icons.
          • 442. Re: Photoshop CS6 does not save icon on Macintosh
            conroy Community Member
            Disabling "Windows Thumbnails" is a superstition. A couple of people have done that and their icon problem has coincidentally ended (because of some change to something else), then they wrongly attribute the change in behaviour to the disabling of "Windows Thumbnails".
            It's like finding a three-leafed clover then having good luck an hour later, and then forever attributing three-leafed clover to good luck.
            • 443. Re: Photoshop CS6 does not save icon on Macintosh
              Here's images I should have posted when writing about TIFF.
              Two from Photoshop:
              Folder view options in Finder:
              • 444. Re: Photoshop CS6 does not save icon on Macintosh
                Donald_Gudehus Community Member
                William,
                In Photoshop preferences, try:
                Image Previews:  Always Save
                     Icon:  Unchecked
                     Windows thumbnail:  Checked or Unchecked
                No need to reboot your Mac or restart Photoshop.  Please tell us if that helps.
                • 445. Re: Photoshop CS6 does not save icon on Macintosh
                  Donald_Gudehus wrote:
                  William,
                       Icon:  Unchecked
                  You will be fine that way which lets the OS create the icon if you have that checked in the OS preferences. I have had Image Previews:  set to Always Save for months now with out a problem.
                  But if the corruption has started you will need at least to log out and then log back in to clear the icon view corruption.
                  I don't believe Windows thumbnail:  Checked or Unchecked has any affect on the icon view corruption in Mac OS started be CS6. It only happens when Icon is checked.
                  • 446. Re: Photoshop CS6 does not save icon on Macintosh
                    This post being a reply to one of yours, Was_DYP, does not imply that I think you're unaware of the content. The post is for any reader.
                    Photoshop preferences uses the term Image Previews to refer to OS X custom file icons and Windows thumbnails. The use of the word Previews can be confusing because OS X can generate another type of icon called a preview icon.
                    Both of the following conditions correctly result in the same non-creation of custom file icons:
                    Image Previews = "Never Save" (which automatically clears Icon checkbox).
                    Image Previews = "Always Save" and Icon checkbox cleared.
                    The Windows Thumbnails status is irrelevant to OS X icons. Enabling it doesn't result in extra thumbnail files, visible or hidden, even when I save to a FAT32 thumb drive so who knows why the checkbox is there?
                    Also, Image Previews = "Ask" never results in me being asked if I want an icon. I find it has the same effect as "Never Save", so who knows why "Ask" is provided as an option?
                    • 447. Re: Photoshop CS6 does not save icon on Macintosh
                      10.8.3 is out. Is it fixed?
                      • 448. Re: Photoshop CS6 does not save icon on Macintosh
                        Chris Cox Adobe Employee
                        Last I heard, Apple was not able to determine the cause, even after hints from users that doing a clean OS install instead of an upgrade fixed the problem.
                        • 449. Re: Photoshop CS6 does not save icon on Macintosh
                          Turning off Windows Icons fixed it for me, a while back.
                          • 450. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                            6i
                            Chris,
                            As I wrote you before, there are not problems at all if you save the .psd on a not-journaled file system. Tell them if they can follow this hint somehow.
                            • 451. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                              enigma51564 Community Member
                              Chris, I did the clean install OS and for a while, that solved the problem.  Now the problem has returned.  If I log out and log back in, it usually restores the missing icons.  Sometimes a simple force quit of the finder will also restore the greyed out icons, but not every time.  I believe this to be a Mountain Lion issue, as you have stated.  Wish Apple would get on the stick and resolve this, but it takes them forever to deal with things like this.
                              • 452. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                The problem that's discussed in this thread is evident on Snow Leopard, Lion and Mountain Lion systems.
                                The problem is one very specific problem. There are other problems with icons in OS X which some people wrongly mistake for the problem that's discussed in this thread.
                                greyed out icons
                                This thread is not about about grayed-out icons. It is about icons not being displayed at all.
                                • 453. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                  Conroy:
                                  I stand corrected.  What I should have said was that this is a MacOS issue, which I do believe Chris has stated.
                                  • 454. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                    6i Community Member
                                    It is, because the icons are showing up fine if the filesystem is not journaled.
                                    • 455. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                      My file system is journaled, and with Windows Icon creation off, I don't have problems any more.
                                      Your mileage may differ.
                                      • 456. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                        6i Community Member
                                        The windows icon creation off, did the trick for me as well, for a couple of days. I don't know, but without the journaling it just works!
                                        • 457. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                          I think you mean "Icon" unchecked, "Windows Thumbnail" checked.  I'm not sure what that actually means for a Macintosh, but it's in the PS preferences.
                                          • 458. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                            To be clear, in the "File Saving Options"
                                            Everything is checked YES (always save, always), except "Windows Thumbnails"
                                            Once I turned that off, my Finder file icons are all good now.
                                            • 459. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                              Looks like you found another solution to the problem!
                                              • 460. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                                MoonRunner 1234 Community Member
                                                None of the above works properly.
                                                As I have mentioned before the fuzzy icon problem and the Photoshop icon problem are related because both problems are temporarily resolved with a log out.
                                                Some of you disagree and say they are separate issues. I’m no expert at this and will not argue the point.
                                                According to posts on the Apple forum, Apple is aware of the fuzzy icon problem but will not be fixing it in Mountain Lion. Once we get an OS X 10.9 upgrade the fuzzy icon problem should be resolved and it will probably also fix the Photoshop problem, at least I hope so.
                                                • 461. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                                  Using your logic, a problem with my broadband access and a problem with fuzzy icons would be related if both were solved by a log out.
                                                  • 462. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                                    As I said, I’m no expert at this, not even the geniuses at the Apple Genius Bar have an answer and I spoke to 3 or 4 different ones. We just have to wait and see because this has been going on for a long time and no one has been able to find a solution to either problem.
                                                    • 463. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                                      The solution at this point is to not use PSCS6 or turn off icon creation in PS6, as to my knowledge no other software starts this corruption of icons.
                                                      • 464. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                                        It has been seen with other software, just not nearly as often.
                                                        We still don't know why Apple's icon display/reading is so unpredictable.
                                                        • 465. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                                          The only "solution" is to never allow Photoshop CS6 to create custom file icons.
                                                          • 466. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                                            With answers like this I wonder if this will ever get fixed.
                                                            I have asked you numerous times what other software starts this icon corruption. Yet you continue to repeat the same "other software" and have not one time named one peice of "other software" that starts this icon corruption.
                                                            Again once started BY PHOTOSHOP CS6 this icon corruption will show up with icons created by other application.
                                                            Unless you can specifically name another peice of software that starts this icon corruption, you need to quit tying to bring unnammed "other software" down to level of bug ridded PSCS6.
                                                            • 467. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
                                                              And that is exactly what I have done for over 6 months now and not one incident of icon corruption created by any "other software".
                                                              • 468. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        Sometimes we can't tell you everything due to NDAs with other companies.
        Remember that just because you don't see something happen does not mean that is does not happen - someone else might see it often. And what you see often, might not happen to most other users.
        • 469. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        Until someone can name one "other software" that starts this icon corruption then the only one at this point appears to be PSCS6.
        • 470. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        Also, if other software updated the file, Photoshop's icons would no longer be present or involved.
        • 471. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        You don't seem to understand the meaning of start here. Once started by PS6 it will show up in all kinds of icons created by other software including the OS. If you then reboot or log out and then back in the corruption started by PS6 will no longer be present and in my experience if PS6 is set to not create custom icons the icon corruption will never show up again.
        • 472. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        That is just more evidence that the problem is in OS code.
        • 473. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        It is not even the presence of Photoshop CS6 icons. It is the icon creation process of PSCS6 that causes the icon corruption. Once rebooted or log out and in the CS6 icons are fine.
        • 474. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        I tried the following experiment:
        With Icon unchecked in Preferences I created a new version of a file.  The icon was visible on the originating Mac Pro (Lion).
        When I looked at the file via sharing with my Power Mac G5 (Tiger) the icon was visible.  It was also visible after copying it to the Power Mac.
        With Icon checked in Preferences I created another new version of a file.  The icon was visible on the originating Mac Pro, but invisible on the Power Mac.  It was still invisible after copying it to the Power Mac.
        Then I unchecked Icon in Preferences and created another new version of a file.  The icon was visible on the originating Mac Pro, and visible on the Power Mac.  It was still visible after copying it to the Power Mac.
        I didn't have to reboot or log out during this test.   Hope this helps.
        • 475. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        grampus45 Community Member
        I'd say the jury is still out.
        The problem occurred for me the first time just a couple of days ago, running 10.8.3.  CS6 has been doing just fine for a number of months, but I created a new document, produced a nice flow diagram, and saved.  No icon.  First time that's happened.
        I saved to another folder.  Same problem.  I tried force-quitting the desktop. Nothing.  So then I tried editing an existing file with an icon and saving.  No icon.
        After reading your insistance that it's an OS problem, I restored my system from my clone.  Same problem.
        I was then going to reinstall PS, but, for some reason, my MacBook Pro's optical drive wouldn't mount the CS6 install disk. So I cleaned the hard-drive and cloned the whole bit back it from my backup.  Problem gone.
        It's not clear from this whether it's an OS problem or a CS6 problem, but it's certainly not certain it's an OS problem.  No other application that I tried while I was having CS6 icon problems did the same thing.
        Now, there was one interesting possible hint.  While I was having the problem, a couple of times I was watching the advent of the file's icon on the disk during the save.  The name came up first, then, very briefly, the generic PS icon, then it disappeared into the blank icon.  So CS6 seemed to be writing the generic icon, but screwed up in making the image icon.
        This, perhaps, explains why people have had some success in turning off icon and/or window thumnail in preferences.
        Also, it suggests an experiment that I can no longer make since I trashed all my icon-less files.  For those who have one, try the following and let me know what happens:
        Option-I click the file to bring up the information panel.  Click in the center of the blank spot at the top left where the icon usually shows (to the left of the file's name).  Then go to the file menu and click "cut."  See if the generic PS icon is lurking behind a blank (transparent) image icon.
        • 476. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        From the reported symptoms, it is clear that this can only be an OS bug.
        From the code involved, it is clear that this can only be an OS bug.
        From all evidence available to date, it is clear that this can only be an OS bug.
        And you were just watching the OS build it's thumbnails, not Photoshop saving the file.
        • 477. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        uhanepono Community Member
        Thanks so much for this! It does indeed do the trick! genius!
        • 478. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        Chris, can you, in any case, get word to your code people with this very helpful clue from grampus45 about the PSD icon absence? Yes, I know it is an apple issue but it might behoove adobe to address it anyway via a coded workaround seeing's apple doesn't seem to care. You are doing heroic work here facing so many disgruntled users on this thread and I appreciate that. Perhaps this new info can lead us all to a solution inspite of apple and out of the shaddow of the valley of entropy.
        • 479. Re: Photoshop CS6 icons sometimes do not appear on Macintosh
        We have notified Apple of this issue, but they cannot reproduce it, nor can we.
        This is dfinitely a bug in Apple's code, but we do not know the triggering factor that causes Apple's code to sometimes fail to read icons/thumbnails/previews correctly.
        We have investigated our code, and found that it all works exactly as Apple says it should, and as we expect it to work.  But we are taking steps to make our file saving code safer in the future (mostly to work around other known Apple filesystem bugs and deprecated functionality).
        The fact that the icons show up for most people, and eventually show for users that have problems, means that the data in the file is correct.   Something just goes wrong for some people, sometimes, on some folders when Apple's code is reading the file to show the icons.
