Our Single SignOn agent (SiteMinder) places a custom variable, HTTP_EMPLOYEEID in the header. Using ASP, I can dump the header info and see that variable/value. But, with a similar CF script, some info, including HTTP_EMPLOYEEID is not there. Any ideas?
Try:
GetPageContext().getRequest().getHeader("HTTP_EMPLOYEEID")
If that doesn't work you may also want to check:
CGI.HTTP_EMPLOYEEID
Thanks for the help. Unfortunately it didn't work. I'm working with my IT people, who installed and configured SiteMinder(user authentication agent) so I haven't dug into that, but they insist the problem lies with CF10. Using the following ASP script I can read the custom header variable EMPLOYEEID: <%= Request.ServerVariables("HTTP_EMPLOYEEID") %> But, with my CF script there doesn't appear to be a header variable by that name. I tried:
GetHttpRequestData().headers.employeeid, then
GetPageContext().getRequest().getHeader("HTTP_EMPLOYEEID"),
and
CGI.HTTP_EMPLOYEEID
Is there any reason why CF10 would not read the entire header content? When I cfdump the header I see other variables, but not EMPLOYEEID. Strange.
It may be the order that the ISAPI filters are being applied. See: http://www.techbiswas.com/2012/12/coldfusion-siteminder-and-iis.html
