Hi Jyothi
I'm going to say it all depends on what you are trying to do.
If all you are talking about is bringing Captivate movies you have
created into RoboHelp, this part does indeed seem to work. As long
as you have no issues using Captivate otherwise, nothing should
surface.
On the other hand, if you are referring to the touted ability
to launch Captivate from inside RoboHelp in order to create a
recording, my experience has been that it doesn't work as well as
I'd have hoped. Captivate does indeed launch and I am able to
record and do things in Captivate, but the silly Publish button is
disabled (many refer to it as "grayed out") so it does me
absolutely no good if I cannot publish into Flash so as to bring
back into RoboHelp.
Sadly, the ability to Right-click and edit the .SWF using
Captivate simply doesn't seem to work.
Lastly, while the Captivate output does seem to allow itself
to be added to a topic properly, if you are using a skin, for some
reason the size changes to something much smaller than what you
intended after inserting. So I'd suggest not using the Borders
feature if you are planning this. This will result in a single .SWF
output. Either that, or tweak the content as needed after adding
it.
Aside from that, things seem fine. Just keep the applications
separated and use them individually. Then mix the output as
desired.
Hopefully this was what you were looking for... Rick
