Weird Axis error CF 7.0.2
Guest
Jan 23, 2007 Jan 23, 2007
I'm getting the following axis error when I try to invoke a webservice, hopefully someone here have seen this before...
It seems that Axis can't write some sort of temp file in the temp folder. Any ideas?? (CF 7.0.2)
Error
Could not perform web service invocation "GetAllDomains".
Here is the fault returned when invoking the web service operation:
AxisFault
faultCode: { http://schemas.xmlsoap.org/soap/envelope/}Server
faultSubcode:
faultString: Server was unable to process request. --> Unable to generate a temporary class (result=1).
error CS2001: Source file 'C:\WINDOWS\TEMP\9tv05qt_.0.cs' could not be found
error CS2008: No inputs specified
faultActor:
faultNode:
faultDetail:
{ http://xml.apache.org/axis/}stackTrace:Server was unable to process request. --> Unable to generate a temporary class (result=1).
at org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:221)
at org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder.java:128)
at org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:1087)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown S...
Code
<Cfinvoke method="GetAllDomains" webservice="#session.basepath#/svcDomainAdmin.asmx?WSDL" returnvariable="domains">
120 : <Cfinvokeargument name="AuthUserName" value="#session.username#">
121 : <Cfinvokeargument name="AuthPassword" value="#session.password#">
122 : </cfinvoke>
123 : <Cfset domainNames=domains.getDomainNames().getString()>
Advanced techniques
503
Advocate ,
Ah, I just noticed that your webservice seems to be returning a complex .NET object. CF sometimes has some problems with complex web service inputs/outputs. Make sure the WSDL is correct by pulling it up in a browser, and if so, then do a forum search on web service errors (I know I've seen a few of them lately). The following article might be helpful:
http://hcc.musc.edu/research/shared_resources/xml_complex_types_to_cf_structure_notes.cfm
(the URL ends in .cfm not sure why its getting cut off)
Guest
Jan 24, 2007 Jan 24, 2007
Cool, thanks man! I think this might work!
I'm not sure why it broke, I think it might be because of the 7.0.2 update and I've seen some stuff about a axis update to 1.3... Not sure if that broke it down, but the link should push me into the good direction!
Thanks again!
Guest
Oh man!
It was a ASP.NET/IIS permission problem!
Sorry for the trouble, thanks for the help!
Documentation
