Compatibility with Windows 8, Office 2013?
Mar 06, 2013 Mar 06, 2013
I am attempting to trial Adobe Presenter and Adobe Captivate. I have downloaded Presenter but cannot install it. I am getting an installation error with code 7: PowerPoint 64-bit cannot be found on my machine. Yet, in my Control Panel System Information it clearly states I am running 64-bit. Are these products compatible with Windows 8 and PowerPoint 2013? If so, what can I try next?
Presenter
3.7K
Adobe Employee ,
Moving this discussion to the Adobe Presenter forum.
Adobe Employee ,
Hello,
Welcome to Adobe Forums
Adobe Presenter 8 is not certified and compatible with MS Office 2013 64bit.
Vikram
If you have PowerPoint 64 bit use the 64 bit installer. If you have PowerPoint 32 bit, be sure to use the 32 bit installer. Your system may be 64 bit, but your MS PowerPoint may be 32 bit.
Engaged ,
Hello,
Adobe Presenter 8.1 - 32bit full installer update supports Windows 8 + Office 2013 32bit.
You can install Office 2013 32bit and then install Presenter 8.1. It will work.
As Jorma mentioned, please download the correct installer of PowerPoint. Look for 32bit installer only.
mukul
Adobe Presenter Team.
Apr 01, 2013 Apr 01, 2013
I am running PowerPoint 2013 (32-Bit) with Adobe Presenter Version 8.  Last night I created a presentation and it worked fine.  This am, for whatever reason, PowerPoint "re-started" and found a conflict with Adobe Presenter 8.  Now, I am unable to "add-in" the Presenter 8 tab into PowerPoint.
I have attempted to locate the "menulauncher.dll" file to no avail (at least Windows Search does not show it).
Did complete shutdown and restart. . .no effect.  Restarted PowerPoint multiple times.  When I go into PowerPoint ("Options") and Add-Ins, it shows that the Adobe Presenter PowerPoint COM Addin is active, but it is not showing on my Powerpoint and I'm unable to use Presenter 8.
Can you help?  Have you seen this before?
My system is running Windows 8, 64 bit (but 32 bit PowerPoint), operating system on "C" drive; Programs on "P" drive.
In the dialog where you see the ad-ins, you should see a drop down to mange the add-ins. Select the Disabled option from the drop down, and then select Presenter and Enable it. Restart PPT and the Presenter ribbon should reappear.
Hi Jorma:
When I open the "Disabled" option it says nothing...there are no add-in's showing as being "disabled."
When I check Adobe Presenter 8 under the "COM" add-ins, save, and re-start PowerPoint it still does not show.  Any other suggestions?
I would try uninstalling and re-installing Presenter. If that doesn't work, then you may need to work with Support to identify the issue and its resolution. Someone from Support may chime in here, and give further guidance as well.
Help resources
