1. Re: h264 compression generate blocks?
SAFEHARBOR11 Apr 5, 2013 8:26 AM (in response to andy-mario)I didn't reply yesterday, hoping someone else would have a better answer. Here goes. What are the Export settings - can you post a screen grab?
Anytime you have a background that is almost a solid color, such as sky or your background, banding can be an issue when working with highly-compressed export codecs. There are just so few steps between the colors that it is difficult to achieve a smooth gradient with the compression being used.
Jeff Pulera
2. Re: h264 compression generate blocks?
Rallymax-forum Apr 8, 2013 2:46 PM (in response to SAFEHARBOR11)SAFEHARBOR11 wrote:
Jeff Pulera
That's simply not true.
The bundled h.264 encoder just makes very poor decisions when it comes to the bit budget.
It's not appropriate for me to mention my 3rd party h.264 encoder but look around this forum and you'll find it talked about.
3. Re: h264 compression generate blocks?
Matt Dubuque Apr 8, 2013 4:18 PM (in response to Rallymax-forum)rallymax, does your critique extend to the standalone AME as well?
Matt
4. Re: h264 compression generate blocks?
Rallymax-forum Apr 8, 2013 4:33 PM (in response to Matt Dubuque)Premiere Pro and AMEpull from a common set of decoders and encoders, so yes, the h.264 encoder is the same.
best regards,
Rallymax
5. Re: h264 compression generate blocks?
andy-mario Apr 15, 2013 5:02 AM (in response to andy-mario)End of story, it was problem of source movie. It has a lot of grain (rallenty at high iso with a low bitrate mxf codec) and I put strong vignettes in grading, that added to the source noise, created a lot of artifacts and blocks, specially over the vignettes. The dark and flat background made it worse.
As a solution I did again the entire color correction keeping it more subtle and with less vignetting, until I got a decent result. AME this time did a good job, but with a third party sofware I did an x264 and looked better. Usually I don't need 3rd party, ame do a good job.
Thanks for all your suggestions, I learned that in these situations (flat background, not perfect lighting) it takes a lot of trial and error to get a good h264!
