3 Replies Latest reply: Apr 3, 2013 5:15 AM by Manuel LP RSS
    How to do pan and scan on single clips?
    andy-mario Community Member
      I have a timeline with multiple clips. I'm trying to do some pan and scan to single clips, pan and scan will be different on each of these clips. I tried to put a new "pan and scan" track, but it covers the complete timeline and I can't reduce it to the duration "covering" a single clip (as you can do with grading track). Is there a quick way to apply pan and scan to individual clips? I came from Apple Color where pan&scan was an individual tab in each clip, so it was really easy to do it and save it inside the look.
        • 1. Re: How to do pan and scan on single clips?
          Manuel LP Community Member
          Yes, "pan and scan" track covers the complete timeline, this is normal. For pan and scan a single clip put a keyframe where each clip starts, this is the way as works SG.
          • 2. Re: How to do pan and scan on single clips?
            I tried to do as you suggested, timeline become cluttered with a lot of keyframes, and I need to put 4 keyframes to each pan, to retain the basic 1.0 scale, otherwise the last keyframe value is applied to everything else.
            I hope Adobe will change this with a more intuitive per-clip pan&scan, always worked on a per-clip basis that in other grading apps and always found it fast and simple.
            • 3. Re: How to do pan and scan on single clips?
              Yes, this method is a little strange, but it works.
              The way is: first create a key in the start of the clips underneath, then set the scale or pan (you can to use the widget). In SG is always first create a key, and after adjust the parameter. If you only want adjust a pairs of clips, remenber to put a key with default parameters in the first clip after last adjusted.
