1. Re: Configurator cs4 panel vertical resize limit
cromaline Sep 16, 2010 5:33 PM (in response to Reillet)Never seen something like this.
The maximum panel Height is 800 pixels and the minimum is 10
The maximum panel width is 1000 pixels and the minimum is 10
when you drag objects in your panel Configurator it doesn't let you insert a value that cannot contain all the objects ( and shows a red box line as shown below)
Your problem sounds strange to me.
I could suggest you to reset photoshop preferences or
uninstall Configurator and try a fresh install, may be something is wrong with the swf generated
2. Re: Configurator cs4 panel vertical resize limit
zhpingw Sep 16, 2010 5:57 PM (in response to Reillet)Hi,
There's a "resize" bug in Configurator 1.0.
When you export a panel, and open it first time, Panel will resize to the width and height you assigned as cromaline say, after first time, panel will not resize, since photoshop will remember last size of your panel.
But if you resize it to a larger size exceed photoshop's default size (220*220), when next time start photoshop
, Photoshop will remember this size, then you can't resize it smaller.
There's a workaround
on Windows system go to folder C :\Documents and Settings\
search file "PanelSizeStore.sol" and delete it.
Then restart photoshop, you can see the panel resize to your initial size.
3. Re: Configurator cs4 panel vertical resize limit
Reillet Sep 16, 2010 6:17 PM (in response to zhpingw)Thanks for the help,
Zhpingw, your workaround was successful!
Marc
4. Re: Configurator cs4 panel vertical resize limit
felicagonza Apr 3, 2013 11:07 PM (in response to Reillet)Hi all, Please help me..
when i can download adobe configuration 1.0 ( for cs4)?.
b'cause i cant download from adobe.comthanks before,
but, if you want to help me. you can send an email to mya.luphyu@yahoo.co.id
