I can't get any Heading 1s to appear in printed Word TOC.
Using Books and Topics (with titles as Heading 1 as a test).
All other headings appear fine in the Word TOC.
RH TOC example
Functionality (Book)
Function 1 (Topic) - has Heading 1 title, doesnt show in word TOC
Function 2 (Topic) - has Heading 2 title, shows in word TOC
Known Issues (Book)
Issues 1 (Topic)
Sure I can change the TOC field codes to include Heading 1 in the Word doc.
Does RH only include Heading 2 and lower in the Word TOC, by default?
Anyway to change this or what am I doing wrong?
Many Thanks,
David
It should work as it always has, I'm not having any issues in this area.
Try one of the sample projects. Click Open on the RoboHelp Starter page and then click Samples in the ribbon on the left.
Are you mapping to a Word template? If yes, try another one.
Tried several templates, same result.
Tried EmployeeCare sample project
Heading 1
doesnt appear in word TOC, nor any other Heading 1s
Only Heading 2 entries appear
I know that project works when mapped to the supplied Word template. What are you mapping to and what version of Word?
Style Mapping - EmpCare.dot
Word 2010
This is the TOC field code
TOC \B RH_PD_TOC_BK \O "2-2" \H \Z \T "Heading 1,1" \* MERGEFORMAT
When I change it manually, works fine
I just tried that one and it worked correctly. I also see the same code so this is a bit baffling.
Have you tried both DOC and DOCX?
Are you generating the Word document to a local drive.
If the problem was with one document or project, I would suggest other things but this is common to all Word outputs.
Try generating a printed document but selecting a CSS file rather than a Word template.
Can you try on another machine using the trial version for test purposes?
I've tried DOC and DOCX....same result.
Generating to local drive.
Used CSS file also, same result.
Yet to try other machine
@david_aker
Problem solved?
nope
Are you able to send me the project? See the Contact page on my site.
David
I replied to your email but haven't heard back from you.
I received the XPJ file only then a project with no topics so I have been unable to assist David. If anyone else sees a similar problem, let me know.
Hi Peter, I'm IT supporter in 3shape company and we have the same issue.
