I'm getting the following axis error when I try to invoke a
webservice, hopefully someone here have seen this before...
It seems that Axis can't write some sort of temp file in the
temp folder. Any ideas?? (CF 7.0.2)
Error
Could not perform web service invocation "GetAllDomains".
Here is the fault returned when invoking the web service
operation:
AxisFault
faultCode: {
http://schemas.xmlsoap.org/soap/envelope/}Server
faultSubcode:
faultString: Server was unable to process request. -->
Unable to generate a temporary class (result=1).
error CS2001: Source file 'C:\WINDOWS\TEMP\9tv05qt_.0.cs'
could not be found
error CS2008: No inputs specified
faultActor:
faultNode:
faultDetail:
http://xml.apache.org/axis/}stackTrace:Server
was unable to process request. --> Unable to generate a
could not be found
at
org.apache.axis.message.SOAPFaultBuilder.createFault(SOAPFaultBuilder.java:221)
at
org.apache.axis.message.SOAPFaultBuilder.endElement(SOAPFaultBuilder.java:128)
at
org.apache.axis.encoding.DeserializationContext.endElement(DeserializationContext.java:1087)
at
org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown
Source)
at
org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown
S...
Code
<Cfinvoke method="GetAllDomains"
webservice="#session.basepath#/svcDomainAdmin.asmx?WSDL"
returnvariable="domains">
120 : <Cfinvokeargument name="AuthUserName"
value="#session.username#">
121 : <Cfinvokeargument name="AuthPassword"
value="#session.password#">
122 : </cfinvoke>
123 : <Cfset
domainNames=domains.getDomainNames().getString()>
