Hi Timbre4
If you click the Storyboard tab and look at the lower left
corner area, you should see a guesstimate of running time.
I say this is a "guesstimate", as there are many factors that
will likely affect the running time. For example, let's say that
you have a 10 slide movie that is set for 3 seconds timing each
slide. One would conclude the movie is 30 seconds long, no? (10 x 3
= 30).
Assuming the movie simply played, this would be accurate. But
let's further assume that on slides 1-9 a button is inserted that
is programmed to jump to the next slide. The button pauses at 1.5
seconds, so if your user clicked really quickly, they might make
the movie progress at a rate of 2 seconds per slide. This would
result in a movie that played for roughly 20 seconds.
Hopefully that made sense... Rick
