Return Soap Fault in CF web service
Apr 05, 2013 Apr 05, 2013
How do I return a Soap Fault like this:
      <soapenv:Fault>
         <faultcode>soapenv:Client.Validation</faultcode>
         <faultstring>SalesCode must be 5 characters in length</faultstring>
      </soapenv:Fault>
instead of a CFCInvocationException?
836
Nov 14, 2013 Nov 14, 2013
Hi Dina,
Did you find a solution to your problem? I'm looking at doing the same thing.
Cheers,
Simon
Nov 17, 2013 Nov 17, 2013
I had to use a workaround. In the complex type (CFC) returned by the web
service, I added two additional properties, success (boolean) and fault
(string). That way, if validation fails, I set success to false and return
validation messages in the fault property using syntax like this:
. It communicates what the client needs to know but
is not in the format I originally wanted to implement. I did find a clue
about how to get control of the SOAP envelope in a comment made by Arthur
Blake at the end of one of Ben Nadel's blog entries about using HTTP to
consume a web service. He said he could customize the XML request/response by
writing a "proxy" in ColdFusion that forwards to the real SOAP service. I
never did figure out how to go about doing that, so if you happen to get
your head around it, please post your solution. In general, I found that
ColdFusion 8 doesn't play nicely with a pre-defined complex WSDL that
import XSDs and doesn't honor a "required=no" setting in the property tag
of a complex type's CFC when generating its WSDL dynamically. In fact, I
have a whole list of "gotchas" on this... Didn't mean to write a book, but
you opened an old wound that had just about healed. Good luck, Simon. Hope
I didn't douse too much water on your passion to move forward with this.
Documentation
