Show 3 replies
1. Re: How do you remove items from the assets panel that are duplicated?
Michael Altringer Apr 3, 2013 5:55 PM (in response to pamela Swanson)Are they the same size? Hover over them in the asset panel to see
2. Re: How do you remove items from the assets panel that are duplicated?
pamela Swanson Apr 6, 2013 10:41 AM (in response to Michael Altringer)They are the same size.
Is it normal to have two copies of the same file listed in the assets?
One item has 4 copies of the same item.
The slide show seems to work fine in preview with the exception that the 4 copy item blinks twice and then proceeds.
Pam
3. Re: How do you remove items from the assets panel that are duplicated?
adobelance Apr 6, 2013 1:09 PM (in response to pamela Swanson)If you add an item to a slideshow, you'll usually see 2 entries for that image in the assets panel - one represents the thumbnail, and the other represents the larger 'hero' image.
It sounds like you may have added the same image to your slideshow twice. You can select one of the hero images or thumbnail images in your slideshow and use the delete key to remove it. Then the extra 2 entries in the assets panel should disappear.
