1. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
RalphDCW Mar 26, 2013 12:09 PM (in response to RalphDCW)Anyone?
2. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
OLI03 Apr 4, 2013 5:52 AM (in response to RalphDCW)Hello,
Have you tried to fix the stage dimensions in %, your objects position and dimensions in %.
I tried and object are proportionnaly resized when the browser window is resized.
One problem : the text size.
Olivier
3. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
sarhunt Apr 4, 2013 9:44 AM (in response to RalphDCW)I have a tutorial in the queue on how to do this. Stay tuned
4. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
RalphDCW Apr 4, 2013 9:54 AM (in response to sarhunt)Hi Sarhunt
That is great news - a solution at last!
Can't wait for your tutorial
Cheers
6. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
resdesign Apr 8, 2013 8:13 AM (in response to sarhunt)Cool Sarah! Thank you for taking the time to create another great tutorial.
7. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
heathrowe Apr 8, 2013 8:15 AM (in response to resdesign)Awesomeness!
Thanks Sarah
d
8. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
Jerry Witt Apr 8, 2013 8:50 AM (in response to heathrowe)Sarah, this is a great tutorial. Thank you.
On the youtube page it points to the files at: http://sarahjustine.com/2013/04/07/create-scale-t...e-edge-animate/ which returns a "Page not found" (although it shows the home page content and is currently easy to find the content). Just thought you might want to know about the bad link on the YouTube page.
9. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
sarhunt Apr 8, 2013 9:31 AM (in response to Jerry Witt)Whups! Should work now
10. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
jkuo1 Apr 8, 2013 11:53 AM (in response to sarhunt)Thanks for the great tutorial! Very informative indeed!
One question I have, however, is that the example seems to scale well when resizing the browser window horizontally, but there seems to be no effect with regards to resizing the window vertically and having the Stage resize proportionally with the Scale-to-Fit behavior that the OP was looking for? For example, if I resize the browser window to a height that is smaller than the current height of the stage, the browser window will start showing a vertical scroll bar rather than proportionally scaling down the stage so the the entire stage remains visible. Is this something that the sample files should be demonstrating or did I miss something?
11. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
sarhunt Apr 8, 2013 12:20 PM (in response to jkuo1)Hi jkuo,
The reason for this is so when your animate composition is placed inside your website, it doesn't get all jacked up based on the height of the viewport. This treads into vertical RWD territory which can lead to unexpected results. You can try playing for yourself by changing the width parameters to height in the sample.
Sarah
12. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
jkuo1 Apr 9, 2013 7:33 AM (in response to sarhunt)Hi Sarah,
I hope you don't mind but I played around with your code a bit and managed to get the kind of scale-to-fit behavior that I believe the OP was asking about. I think the trick is to make sure that you also check whether the scaled height of the stage exceeds the height of the browser window and change the scaling so that it is responsive to changes in both the width and height of the window, whichever is the limiting factor. The code I changed in CompositionReady appears in bold below. I hope this helps.
sym.$("#Stage").css({ // Set the transform origin so we always scale to the top left corner of the stage
"transform-origin":"0 0",
"-ms-transform-origin":"0 0",
"-webkit-transform-origin":"0 0",
"-moz-transform-origin":"0 0",
"-o-transform-origin":"0 0"
function scaleStage() {
var stage = sym.$('Stage'); // Set a reusable variable to reference the stage
var parent = sym.$('Stage').parent(); // Set a reusable variable to reference the parent container of the stage
var parentWidth = stage.parent().width(); // Get the parent of the stage width
var parentHeight = $(window).height(); // Get the browser window height
var stageWidth = stage.width(); // Get the stage width
var stageHeight = stage.height(); // Get the stage height
var desiredWidth = Math.round(parentWidth * 1); // Set the new width of the stage as it scales
var desiredHeight = Math.round(parentHeight * 1); // Set the new height of the stage as it scales
var rescaleWidth = (desiredWidth / stageWidth); // Set a variable to calculate the new width of the stage as it scales
var rescaleHeight = (desiredHeight / stageHeight); // Set a variable to calculate the new height of the stage as it scales
var rescale = rescaleWidth;
if (stageHeight * rescale > desiredHeight) // Do not scale larger than the height of the browser window
rescale = rescaleHeight;
// Rescale the stage!
stage.css('transform', 'scale(' + rescale + ')');
stage.css( '-o-transform', 'scale(' + rescale + ')');
stage.css('-ms-transform', 'scale(' + rescale + ')');
stage.css('-webkit-transform', 'scale(' + rescale + ')');
stage.css('-moz-transform', 'scale(' + rescale + ')');
stage.css('-o-transform', 'scale(' + rescale + ')');
parent.height(stageHeight * rescale); // Reset the height of the parent container so the objects below it will reflow as the height adjusts
// Make it happen when the browser resizes
$(window).on('resize', function(){
scaleStage();
// Make it happen when the page first loads
$(document).ready(function(){
scaleStage();
13. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
sarhunt Apr 9, 2013 8:08 AM (in response to jkuo1)Nice! I intentionally left that part out since in the website example I provided checking for height would've jacked up the layout. Good to have the use cases covered, thanks for sharing!
Sarah
14. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
miruko_86 Apr 14, 2013 2:57 AM (in response to sarhunt)there is a way to resize the stage by height instead width? thank's!
15. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
RalphDCW Apr 14, 2013 11:42 AM (in response to sarhunt)WOW!
Many thanks Sarah for listening to our pleas and coming up with a brilliant solution to the Scale-to-fit problem.
And many thanks Jkuo1 for updating Sarah's solution to respond to browser window height as well as width.
The problem is 99% solved - but there is just one little thing that would make your collective solution absolutely perfect and a complete match for the way scale-to-fit works in Flash:
Is there any way that the animation can be centred instead of ranged left or right?
For that matter, is there any way the sort of responsive animation you show in your 'Resize' tutorial can be created so that the main part of the design stays in the centre of the browser window and the background extends both left and right (rather than just right) as the window width is increased? It just seems a pity that the Position and Size options in Edge Animate only show four positions (the corners) and not 9 positions (the corners plus centers) as you get in so many other programmes.
Sorry if I seem ungrateful. I may be asking the impossible. But "Don't ask, don't get" has always been my motto!
16. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
sarhunt Apr 14, 2013 2:07 PM (in response to RalphDCW)Hey Ralph,
Glad you liked it! Though I don't think I entirely understand what you're trying to accomplish. In the sample files I posted the composition is centered:
http://sarahjustine.com/demos/scaletofit/
Is that what you're trying to do?
Sarah
17. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
RalphDCW Apr 15, 2013 2:41 AM (in response to sarhunt)Hi Sarah
My apologies. I've re-read my post and realise I haven't made myself clear.
You are right of course that in your sample files, the composition is centred. However in your files the composition doesn't scale if only the height of the browser is reduced. What I'm talking about is the result I get using your file with Jkuo1's code. Yes, the composition stays centred whatever the width of the browser. But, on a largish monitor, if the browser is reduced in height, the composition stays ranged left. I want it to stay centred.
Any ideas?
18. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
BigMucho Apr 15, 2013 10:34 AM (in response to RalphDCW)A few tweaks to the Edge HTML / CSS and you're good to go. Inside Edge, make sure all height and width units are set to percentage (including the stage). This technique also works well with non-Edge content, no jQuery required.
HTML:
<body>
<div id='aspectwrapper'>
<div id='content'>
<!-- The Good Stuff Lives Here -->
</div>
</div>
</body>
CSS:
#aspectwrapper {
display:inline-block;
width:100%;
position:relative;
#aspectwrapper::after {
padding-top:56.25%;
// Use this percentage for 16:9, get yours via: Height / Width * 100
display:block;
content:'';
#content {
position:absolute;
top:0;
bottom:0;
right:0;
left:0;
overflow:hidden;
19. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
kellisswan Jul 9, 2013 11:19 AM (in response to BigMucho)THANK YOU BigMucho for this tweak! I've been trying to find an answer to this for days. My banner animation is now responsive on all devices. :-) I'm going to share your info (with credit to you of course), on another thread. [http://forums.adobe.com/message/5398804#5398804]
Later update: Unfortunately I ran into some difficulties with the html/css solution later, and couldn't get them resolved. So, I took the time to watch Sarah's video (link in earlier post) and that allowed me to create a new animation that is fully responsive/scalable. (http://www.pencilplace.com)
20. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
cece87 Jul 9, 2013 11:31 AM (in response to jkuo1)Hello,
thank you very much for the solutions, they work very well! :-)
A last problem remaining is with Firefox, where i get a lot of white space left under the scaled animation and with IE9, where the space is under and right the animation. The scroll is therefore active, what could it be? What can i do?
Thank you
Cheers Cece
21. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
sdisp2013 Jul 26, 2013 7:48 AM (in response to jkuo1)Thank you this works perfectly in Edge Animate CC. I had a fix that did work with Edge Animate CS6 version, but this one works perfectly. I have spent hours and hours trying to find a fix for this!
22. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
ladobeugm Sep 13, 2013 12:57 PM (in response to BigMucho)I just tried BigMucho's advice on this project, but the content is still appearing top left no matter what. And it's only scaling 100% height or width, but not both. Where am I going wrong on this? I already tried addingg text-align: center; and margin: 0 auto; in a number of places but it didn't change a thing.
Also, I notice with this method that my preloader image, which should be centered, isn't even close. It's more like the bottom right when I test. How can I make certain this is centered when this is running? It's very important! We're going to be loading a lot of scripts here eventually.
23. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
sykologic Sep 19, 2013 5:21 AM (in response to RalphDCW)I have the same problem as RalphDCW.
Has anybody found a solution for this?
24. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
PEPPERFACE Oct 5, 2013 6:32 AM (in response to sarhunt)Absolutely spot on. Many thanks, Sarah, it all works brilliantly.
Just one thing, though... is there any way to apply the same scaling to preloader content? As it stands, the preloader remains at its actual size whilst running - or at least it fails to scale up in the same way as the main stage - which means there's an unpleasant, visual 'leap' when the main animation runs and fills the window. Any tips or a steer in the right direction would be hugely appreciated
Cheers!
Frannie x's
PS: I also posted my request on your YouTube vid coments but will indicate in both posts if a solution's found
26. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
AdobeDope101 Oct 18, 2013 9:03 PM (in response to shotdang1970)PLEASE HELP ME!
I am so sorry but I am beyond desperate. I keep finding so many forums that point back to your script, which I am sure means that it is correct, but my animation refuses to work.
Essentially I have the same problem as everyone else, I am trying to get my parallax animation to adjust to the screen size. I have watched your tutorial video and read other forum threads, but I cannot get it to work. I have tried fixing it in dreamweaver, muse and animate, and still nothing. And I tried opening a new file, pasting only that script in the compReady command and running that, still nothing :[
What am I doing wrong?
27. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
satanzhand Nov 18, 2013 5:38 AM (in response to jkuo1)I had just about pulled all my hair out on this. Nothing has worked except your scripts! Thank you bigmucho now I can sleep again!
28. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
Zoze Dec 17, 2013 8:17 AM (in response to satanzhand)Hi,
thank you all of you for you guidence and your helpfull advices.
Currently, I used the above updated Sarah's code by jkuo1 to fit-scale the composition but. it doesn't work good.
The height works great but the width doesn't work well, it appears a blank area at the right of the screen. It doesn't fit on it.
As the image below.
How is possible to fit in the window?
29. Re: Are Adobe EVER going to make Edge Animate scale-to-fit (like Flash)?
Beck Graben Apr 30, 2014 4:59 PM (in response to sarhunt)Cool, thanks! Is it possible to achieve the same thing with a published .oam file and then dropped into muse? I'm simply looking to have animation adge animate project span to both edge of the browsers widths but keep the animation centered... HELP!
