Itext Problem
Jan 16, 2007 Jan 16, 2007
I get the following problem when trying to use the refactored iText 1.4.6.
Class coldfusion.runtime.java.JavaProxy can not access a member of class com.lowagie.textNew.pdf.PdfWriter with modifiers "protected"
Im trying to call the following function.
pdfWriter.setViewerPreferences(PdfWriter.HideToolbar);
Is there anyway around this?
Advanced techniques
2.4K
short of doing some java wrappers, nope. it's the "protected" bit.
Thanks Paul
I'm looking at trying to make it harder for a user to either alter, save or print a PDF. One way seemed to be through setting viewerpreferences and removing all the tool bars. The other way is to set permissions and not allow printing.
Have you any examples of how to do this?
> printing.
no, not offhand but you *can* either set user permissions when you create the
doc via PdfWriter setEncryption method or read in an existing PDF & "stamp"
encryption on it via PdfStamper setEncryption method (or use PdfEncryptor class
encrypt method). note that for all these methods you'll need to add a password
to the PDF.
Jan 25, 2007 Jan 25, 2007
Hi Paul
I've come up with the following
newPDF=createObject("java","java.io.FileOutputStream").init(expandPath(finalOutPutFile));
pdfStamper=createObject("java","com.lowagie.textNew.pdf.PdfStamper");
newPDF=pdfStamper.setEncryption('','',AllowPrinting,0);
Is that even close? Currently, I get an AllowPrinting is undefined error.
The notes suggest that the command should accept an int and yet the options inlude allowprinting etc..
AllowPrinting is a user permission *field* in PdfWriter. if you have initialized
a PdfWriter class then you can do PdfWriterObjectName.ALLOWPRINTING or simply
javacast on it's value, 2052.
newPDF=pdfStamper.setEncryption('','',javaCast("int",2052),0);
if i can offer some advice, grab a copy of bruno's book if you plan on doing
much w/Itext. very good value.
Jan 26, 2007 Jan 26, 2007
I get the following error
The selected method setEncryption was not found
I'm using a itext 1.4.6.
post enough of your code to see what's going on.
Here is the code.
Its a copy of the concatenate pdf code from a previous post - as this removes all the security I need to add it back on.
if (i EQ 1) {
pdfDocument.init(reader.getPageSizeWithRotation(1));
pdfCopy.init(pdfDocument, newPDF);
// make sure we turn off printing BEFORE we open the new PDF
pdfCopy.setEncryption(false,"","",bitNot(pdfCopy.ALLOWPRINTING));
pdfDocument.open();
} // first file in list?
Feb 01, 2007 Feb 01, 2007
Thanks Paul....
Participant ,
Feb 20, 2007 Feb 20, 2007
Has anyone got into a problem generating very large pdf files. Our process kills the jrun once the pdf file generated is larger than 14mb?
Apr 02, 2007 Apr 02, 2007
ok it works for me, but just for one parameter a the same tilme.
pdfCopy.setEncryption(pdfCopy.STRENGTH128BITS,"","123456789",bitNot(pdfCopy.AllowModifyContents));
if I repeat this line with different attributes (AllowPrinting...) it's not working
The docs said that it's possible to concatenate multpiles "AllowXXX" using | (pipe) but it does not work !
I want to do the following thing :
no password for reading
a password for editing
without password, you can read & print the PDF, but nothing else (not removing a page, not edit text, ...)
How can I do ?
what ver of iText? show your code.
Apr 03, 2007 Apr 03, 2007
I use Coldfusion 7.0.2 with the itext that came with it.
My code (99% based on yours 🙂 :
if (i EQ 1) {
// make sure we turn off printing or modifying or ... BEFORE we open the new PDF
passwd = createuuid() ;
pdfCopy.setEncryption( pdfCopy.STRENGTH128BITS, "", passwd, bitNot(pdfCopy.AllowModifyContents)
pdfDocument.open();
If I replace "bitNot(pdfCopy.AllowModifyContents)" by "pdfCopy.AllowScreenReaders | pdfCopy.AllowCopy | pdfCopy.AllowPrinting". I have the following error : "Invalid token '|' found on line 310 at column 100."
Apr 04, 2007 Apr 04, 2007
sorry to take so long, been a bit busy.
the "|" char is java syntax for bit ORed. so to cobble together different
permissions that you want to negate you might do something like:
pdfPermissions=bitOr(pdfCopy.ALLOWPRINTING,pdfCopy.ALLOWCOPY);
// don't allow any of the pdfPermissions
pdfCopy.setEncryption(pdfCopy.STRENGTH128BITS,"",passwd,bitNot(pdfPermissions));
if there's more than two permissions you need then maybe:
pdfPermissions=bitOr(pdfPermissions,pdfCopy.ALLOWMODIFYCONTENTS);
pdfPermissions=bitOr(pdfPermissions,pdfCopy.ALLOWASSEMBLY);
etc.
Documentation
