1. Re: I am getting ? when I want £
osgood_ Apr 10, 2013 4:56 AM (in response to matthew stuart)matthew stuart wrote:
I have got a website with LOADS of the British pound symbol '£' all over it, rather than £ which is held in the database rather than hard coded n the page.
I've got on all pages the <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> to translate to the correct symbol. I have looked in the admin section of the site and the text and textarrea boxes all have ? instead of £. If I change it to a pound, then it displays correctly on the site.
What I think is causing this is I have exported the database and loaded it on the remote server, and I think it's the export and import process that's changing the £ to a character that MySQL doesn't recognise. Is this the case? If so, how can I stop it?
Thanks.
So what's in the database field - £ or £?
When you exported and imported to the database was it £ or £?
Try deleting one of the £ in the database and physically typing it in there and then testing it by calling it onto the page via the database.
I experience weird characters a lot if I insert text directly into a database which has been provided in word or pdf format.
The pounds usually show up as black diamonds with a ? mark in them if they are incorrectly input into a database from what I can recall from memory
2. Re: I am getting ? when I want £
Ben Pleysier Apr 10, 2013 6:35 AM (in response to matthew stuart)I think it unwise to have the currency symbol in the database. In doing so, it needs to be a text field (or similar) eliminating any chance of mathematical operations.
It is far better to create a function that shows currencies with the relevant symbol.
3. Re: I am getting ? when I want £
mhollis55 Apr 10, 2013 6:53 AM (in response to matthew stuart)One thing you can do is to have php print the appropriate string every time it encounters that character.
So your php would see £ and print £
