1. Re: Creep problem - Phaser 7800 Booklet
Rayven Wolfe Apr 10, 2013 6:26 AM (in response to Rayven Wolfe)I suppose I should also ask after reading some on the PDFs in posts here...
Is there a difference if we try to print from Reader than from Acrobat Pro X?
I also saw mention of Export versus Print->Choose PDF. Can the difference between these two methods be explained?
2. Re: Creep problem - Phaser 7800 Booklet
P Spier Apr 10, 2013 6:38 AM (in response to Rayven Wolfe)I have a 7800, and I love it, but I don't have the finisher so I can't really help much with the original question.
As far as I know there shouldn't be a difference between Reader and Acrobat Pro, but it's pretty easy to find out...
And as far as printing the PDF, I don't see why exported PDF should behave any differently from printed PDF. Exported PDF supports layers, live transparency, interactivity and color management which you don't get with printed PDF, however.
Of course, you cannot export PDF using Print Booklet, so unless you choose to impose using some other method, that's moot. Have you asked Xerox support about this? Are you using the postscript driver?
3. Re: Creep problem - Phaser 7800 Booklet
Rayven Wolfe Apr 10, 2013 6:57 AM (in response to P Spier)I'm not in the room (or in the same city) with the printer at the moment so I can't continue my test prints. But it is a thing I will investigate.
I do notice that if I use Print Booklet and choose, in the Print Settings, the Adobe PDF as the printer, I do get a pdf that has all the pages in the proper booklet order and, at least on my screen, I see no creep weirdness.
I have done test prints both with the standard driver and the PS driver for the Phaser. I usually use the PS driver, but I did try the regular one just to rule out any differences. I saw no marked change in the printed results.
We have not yet contacted Xerox. I figured I'd post here first because I'd be much more likely to find an InDesign user with a Phaser and I've gotten prompt and thoughtful help here in the past.
Message was edited by: Rayven Wolfe (spelling error)
4. Re: Creep problem - Phaser 7800 Booklet
P Spier Apr 10, 2013 7:14 AM (in response to Rayven Wolfe)As I said, I don't have the finisher, but my guess would be that you won't be able to use the booklet maker with an imposed PDF (printed from Print Booklet). In my experience to get folding and stapling you have to let the machine ptu two pages together, and that won't work with a pre-imposed spread.
5. Re: Creep problem - Phaser 7800 Booklet
Rayven Wolfe Apr 10, 2013 7:30 AM (in response to P Spier)Well I did notice there is a way to ask the printer to do a booklet fold but NOT use a booklet layout. I just sent a test file to my instructor who is on site to see if it changes anything in the output.
I continue to read horror stories about the Print Booklet feature. How do professions who print these things in the real world set up their pages in InDesign to make it suitable to print then? When I started school a couple years ago, they had us manually reordering pages and all that, but it seems in a real-world application, having to do that with larger documents would be harrowing and terribly disruptive to workflow..
6. Re: Creep problem - Phaser 7800 Booklet
MW Design Apr 10, 2013 7:39 AM (in response to Rayven Wolfe)Imposition is largely the work of the service bureau / printing establishment. So the PDF is sent in natural reading order. Doesn't help you in this case.
Mike
