Dear,
I'm just turning into FMS 4.5 and would like to stream to both Flash and iOS.
I installed FMS 4.5 and streaming to the live application and its working fine.
As you already know, to deliver to both Flash and iOS, I've to use livepkgr for HTTP streaming, but, infortunately it won't play up when using of the suggested playback tool.
I've well configured Flash Media Encoder for syncronisation, rtmp://localhost/livepkgr in the FMS URL field and livestream?adbe-live-event=liveevent in the Stream text box for single HTTP streaming. When trying to play the streaming through this HTTP URL:
http://localhost:8134/hds-live/livepkgr/_definst_/liveevent/livestream.f4m
It show this message: We are having problems with playback. We apologize for the incovenience.
If I type http://localhost:8134/hds-live/livepkgr/_definst_/liveevent/livestream.f4m direct in the browser url bar to see if the file exist, here is what I got:
<manifest xmlns="http://ns.adobe.com/f4m/1.0">
<streamType>live</streamType>
<duration>0</duration>
<bootstrapInfo profile="named" url="../../../streams/livepkgr/streams/_definst_/livestream/livestream.bootstrap" id="bootstrap8547"></bootstrapInfo>
AgAKb25NZXRhRGF0YQgAAAAAAAV3aWR0aABAhAAAAAAAAAAGaGVpZ2h0AEB2gAAAAAAAAAx2aWRlb2NvZGVjaWQCAARIMjY0AAxhdWRpb2NvZGVjaWQCAAQubXAzAAphdmNwcm9maWxlAEBTQAAAAAAAAAhhdmNsZXZlbABANgAAAAAAAAAPYXVkaW9zYW1wbGVyYXRlAEDVfAAAAAAAAA1hdWRpb2NoYW5uZWxzAEAAAAAAAAAAAAl0cmFja2luZm8KAAAAAwMACXRpbWVzY2FsZQBAj0AAAAAAAAAIbGFuZ3VhZ2UCAANlbmcAAAkDAAl0aW1lc2NhbGUAQI9AAAAAAAAACGxhbmd1YWdlAgADZW5nAAAJAwAJdGltZXNjYWxlAECPQAAAAAAAAAhsYW5ndWFnZQIAA2VuZwAACQAACQ==
</metadata>
</media>
</manifest>
Please your quick help is really needed.
Check if you have crossdomain.xml policy file in the webroot folder of FMS root install directory. If the file is present and still you are not able to play then you can try the following steps:
You might check both the apache error log and fms application log to see if you have any exceptions.
