1. Re: Ignore camera-generated folder names ...
RikkFlohr Apr 11, 2013 12:51 PM (in response to AttilaHan)You have to have multiple image folders on your memory card for this to have effect. Do you? Or do you just have the single image folder?
2. Re: Ignore camera-generated folder names ...
AttilaHan Apr 11, 2013 12:54 PM (in response to RikkFlohr)Yes Rikk ... I have multiple image folders on my card.
3. Re: Ignore camera-generated folder names ...
RikkFlohr Apr 11, 2013 12:56 PM (in response to AttilaHan)Ok Step One down.
Step Two. How do you have your import dialog set? Into Folders by Date? Into a Single Folder?
4. Re: Ignore camera-generated folder names ...
AttilaHan Apr 11, 2013 1:00 PM (in response to RikkFlohr)At the source panel, I choose "devices" and there are two options in the destination tab as you mention. I have tried every possible combination but I can't see any difference when this preference checked or not checked.
Which one I should choose, folders by date or single folder?
5. Re: Ignore camera-generated folder names ...
RikkFlohr Apr 11, 2013 1:08 PM (in response to AttilaHan) -
6. Re: Ignore camera-generated folder names ...
AttilaHan Apr 11, 2013 1:16 PM (in response to RikkFlohr)I have also tried "files" in the source section with this preference checked and not checked ... but when I check this option (meaning "ignore folder names"), I still see the same destination panel with the original folder names ... LR does not ignore anything.
7. Re: Ignore camera-generated folder names ...
AttilaHan Apr 11, 2013 1:24 PM (in response to AttilaHan)I mean I can't see any difference between two cases ... option is checked or left unchecked.
I don't know where to look at in order to see the difference this option creates.
8. Re: Ignore camera-generated folder names ...
RikkFlohr Apr 11, 2013 1:33 PM (in response to AttilaHan)Mac or PC?
9. Re: Ignore camera-generated folder names ...
AttilaHan Apr 11, 2013 1:34 PM (in response to RikkFlohr)PC
10. Re: Ignore camera-generated folder names ...
AttilaHan Apr 12, 2013 12:46 PM (in response to AttilaHan)I still can not see any difference ... is it a Mac only feature? Any help, thanks.
11. Re: Ignore camera-generated folder names ...
Allan_Olesen Apr 13, 2013 6:44 AM (in response to AttilaHan)Which import option are you using?
"Copy as DNG", "Copy", "Move" or "Add"?
12. Re: Ignore camera-generated folder names ...
tunney moriarty Apr 13, 2013 6:59 AM (in response to Allan_Olesen)Copy
Tunney
13. Re: Ignore camera-generated folder names ...
AttilaHan Apr 13, 2013 7:49 AM (in response to Allan_Olesen)I think that I tried every possible combination ... I would like to learn with which settings I can see that this preference works and creates a difference. Cheers.
