Hello,
I have a test case that will not run due to proceedOnEvent not seeing the desired event. Here's the test code:
package com.mine.components.buttonBar
import flexunit.framework.Assert;
import mx.collections.ArrayList;
import mx.core.FlexGlobals;
import mx.events.FlexEvent;
import org.flexunit.async.Async;
import org.fluint.uiImpersonation.UIImpersonator;
import org.hamcrest.assertThat;
import org.hamcrest.collection.hasItems;
import org.hamcrest.object.equalTo;
import org.hamcrest.object.notNullValue;
public class ButtonBarTest
private var buttonBar: ButtonBar;
private var buttonData: Array = [{label: "one" },{label: "two"},{label: "three"},{label: "four"},{label: "five"}];
[Before(async, ui)]
public function setUp():void
buttonBar = new ButtonBar();
buttonBar.dataProvider = new ArrayList( buttonData );
Async.proceedOnEvent( this, buttonBar, FlexEvent.CREATION_COMPLETE, 3000 );
UIImpersonator.addChild( buttonBar );
[After(async,ui)]
public function tearDown():void
UIImpersonator.removeChild( buttonBar );
buttonBar.dataProvider = null;
buttonBar = null;
[BeforeClass]
public static function setUpBeforeClass():void
[AfterClass]
public static function tearDownAfterClass():void
[Test(async, ui)]
public function testGet_selectedIndices():void
assertThat( buttonBar, notNullValue() );
var selectedIndices: Vector.<int> = buttonBar.selectedIndices;
assertThat( selectedIndices, notNullValue() );
assertThat( selectedIndices, equalTo( 0 ) );
buttonBar.selectedIndices = new Vector.<int>( 0, 2, 4 );
assertThat( buttonBar.selectedIndices, hasItems( 0, 2, 4 ) );
I can run the test within flashbuilder or from ant using a test runner and I get the same result.
The button bar component is derived from spark.components.SkinnableDataContainer and has its own skin. Buttons are added to a DataGroup, one button for each dataProvider element. The buttons and data group are added by the skin classes associated with the button bar.
I am using flexunit-4.1.0-8-4.1.016076.
I'd really appreciate some help in getting this test case to work correctly.
Jeff
It's been a week so ... bump.
It's been over a year now. Were you able to find a solution to this? I am getting the exact same issue. If, instead of calling UIImpersonator.addChild()method, I call FlexGlobals.topLevelApplication.addElement(), the test passes.
Here's a simple test that uses UIImpersonator and fails (timeout):
[Test(async, ui)]
public function test():void
var c:UIComponent = new UIComponent;
Async.proceedOnEvent(this, c, FlexEvent.CREATION_COMPLETE);
UIImpersonator.addChild(c);
However, the following test passes:
[Test(async, ui)]
FlexGlobals.topLevelApplication.addElement(c);
I have tried building with Flex versions 4.6.0, 4.9.0 and 4.9.1 ending up with the exact same output each time. I am using the latest version of FlexUnit.
In the first example, your component is added to a container attached to the system root (so a peer to the application) in the second you are attaching it directly to the application. There isnt a good reason why one should work for you and one not. However, all of the verions of Flex you mention were released after the latest release of FlexUnit so there is the chance that something changed.
I will take a look at this for you, but I can't promise when that will happen so for the moment, if the topLevelApplication trick is working, I see little wrong with that. The only thing to be aware of is that your topLevelApplication may attempt to resize, etc. based on adding a child so it might affect test time.
It may be easier to add a fixed with container (canvas or similar) to the application and then specifically target that just to mitigate the response. Another possibility, if you wish to try, you can actually pass a visualDisplayRoot to the FlexUnitCore when you instantiate it. I believe I saw you doing so in your other post.
So, you can try saying
var core:FlexUnitCore = new FlexUnitCore();
core.visualDisplayRoot = this; //assuming this is running from the main app
Some additional thoughts. If this is a Spark only project:
If flexunit is running an mx only or mx/spark environment it builds a Container for your tests. If it cannot find mx.core.Container at runtime, it builds a Group.
Group doesnt let you call addChild. It expects you to call addElement()
Mike
Thank you! I will try out your suggestions.
Just an update: Flex 4.5.1 behaves the same way. Which version of the SDK do you guys use to test?
Our build server is testing this against 3.2-3.4 and 4.0 and 4.1.
It hasnt been updated for releases after that.
It uses the CI listener and does pass all tests, including a bunch that are async. Did you try the addChild versus addElement thing. If you are using spark, it seems likely
Mike
With UIImpersonator.addElement(), I get this issue: http://stackoverflow.com/questions/7456760/flexunit-spark-component-test-issue-uiimpersonator. It's not a Spark-only project though.
I will probably just use topLevelApplication.
Use topLevelApplication for now and I will spend some time trying to resolve this in a better way. As the post mentiones FlexUnit is being moved to the Apache Flex project so we havent been actively developing but I can try to figure this out and release a patch.
Thanks for your time investigating and I will post back here when I have a resolution.
Mike
