I created a datasource from my CF admin using JDBC/Oracle Thin Client. The datasource creation was successful.
When Oracle encryption is configured as "Requested" I can browse my CF app. and ran many functionalities with no problem
But when the Oracle encryption is configured as "Required" the connection failed.
The way I tested and know that it was failed was when I login in to my web app. It won't log me in. But when the Oracle is switched back as "Requested"
I can login successfully and ran may tasks.
I have CF8 Enterprise version in Unix
From the network dept, I was told they have the correct JAR file in place but did not tell me what is the correct JAR file
Currently my web apps are running with datasource created using Oracle Thin Clint but the Oracle encryption needs to be switched back to "Requested" otherwise my users are complaining that they can't login.
Where should I go from here???? has anyone ever experienced this situation and found a solution? What is going on with my situation, what should I do to fix Please help.
Does anyone know how to contact support to get technical support from Adobe ColdFusion to get some assistance for my situation? also how do we know that the product we own include technical support, do we need some kind of a number? does Adobe has technical support for ColdFusion 8?
I called 1-800-833-6687 and there is no choice for ColdFusion. Is ColdFusion dead or something?
Please check the pm sent to you.
Anit Kumar
Hi Anit Kumar, sorry but I don't understand your short message. What is the PM?
I sent you a PM (Private Message). Oracle 11g is not supported by Adobe with ColdFusion 8. Please refer to http://www.adobe.com/products/coldfusion/pdfs/cf8_systemsupportmatrix.pdf for a detailed list of supported environment.
Anit Kumar
Anit Kumar,
Is the problem connecting to Oracle Think Client can be solved by installing CF 9?
Our department has CF 9
Please let us know
We have been having this problem since a week ego
I'm still contacting some people about the Extended Support Contract
Thank you,
Alec
