I either can't get Flash Player installed (seems be be on my C drive) or it won't connect. Help! OS= Windows 7, IE 10 browser.
Does anyone have an 800 number to talk to a real person???
Message was edited by: Macallan46
Sorry, your post is very unclear...
"can't get Flash Player installed": do you get any error messages?
"it won't connect": connect to what - do you get any error messages?
Try installing using the download from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#main-pars_hea...
To open some web sites, it says I need Adobe Flash Player. When I load Flash Player, it seems to load fine with no error messages. However, when I go to open the site and run the video, I get the same message saying to “load Adobe Flash Player.”
I perused the Adobe web, and the link below. I tried to load via the link you proposed, and the procedure was different, took longer, and established some folders on my C drive. However, I still cannot load the videos on the web sites. Same “load Adobe Flash Player” message. When I investigated the folders on my C drive, there did not seem to be any content.
I use IE 10 and Windows 7.
Sorry, I didn't see your mention of IE10 in your original post. IE10 comes with Flash Player preinstalled; you don't need to (and cannot) install it manually.
See http://helpx.adobe.com/flash-player/kb/flash-player-issues-windows-8.html
So what do I need to do to get it to run? Every time I open a site that says I need Flash Player, it does not run, connect, etc.
Did you check all the options in the document I linked to?
I hope I have found a solution. The video works if I disable my ActiveX Filtering. Does that sound reasonable? What else will that affect?
This FAQ has links to what this feature does and also gives you additional options if you'd like to keep this enabled.
