an error occurred in the script on this page
line 1
char: 15965:
object expected code 0
url http://127.0.0.1:1857/app/_js/abode.js
do you want to continue running scripts on this page
yes no
Run a virus scan on your pc.
Moving this discussion to the Installing Flash Player forum.
Are you seeing this when you run the installer? Or is this occuring on a page with Flash content after the update was completed?
see when try to run installer
use norton to keep machine healthy - all updates done automatically
What is your operating system?
windows XP
will try a complete uninstall and reinstall
latest error is:
Interent explorer script error
an error has occurred in the script on this page
line: 1
Char: 13225
Error: 'actionGtbCheck' is undefined
Code: 0
url: http://127.0.0.1:1288/app/_js/abode.js
do you want to continue running scripts on this page?
yes no
Thanking all for your interest in fixing problem
Download and run the offline installer(s) from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#main-pars_hea...
Did a complete uninstall , even download the uninstall utility
rebooted machine, also running IE 8.0.6001.18702
Tried downloading the installer and re installing failed.
Now getting frustrated. Found the help page a little confusing with many of the links not responding to clicks.
Why do you need to install by running the installer. what happens if you just download the software and run and attempt install from your local machine. Could not find a method to download the actual software.
now wish to install and earlier version while the problem is fixed. worst thing is I am now locked into needing the software. The problems and waste of time makes me look for alternatives.
Find the web pages of archived versions of minimal use because ther eis now indication of what version goes with xp and Ie8
eg what do I use from below
•(Released 4/9/2013) Flash Player 11.7.700.169 (155.54 MB)
•(Released 4/9/2013) Flash Player 10.3.183.75 (61.21 MB)
•(Released 4/9/2013) Flash Player 11.2.202.280 (32.09 MB)
•(Released 3/12/2013) Flash Player 11.6.602.180 (146.09 MB)
•(Released 3/12/2013) Flash Player 10.3.183.68 (61.21 MB)
•(Released 3/12/2013) Flash Player 11.2.202.275 (32.08 MB)
•(Released 02/26/2013) Flash Player 11.6.602.171 (146.38 MB)
•(Released 02/26/2013) Flash Player 10.3.183.67 (61.16 MB)
•(Released 02/26/2013) Flash Player 11.2.202.273 (61.16 MB)
•(Released 02/12/2013) Flash Player 11.6.602.167 and 11.6.602.168 (146.38 MB)
•(Released 02/12/2013) Flash Player 10.3.183.61 and 10.3.183.63 (61.16 MB)
•(Released 02/12/2013) Flash Player 11.2.202.270 (32.06 MB)
•(Released 02/07/2013) Flash Player 11.5.502.149 (146.38 MB)
tried again and get this error
latest error
line: 1
char: 10137
error: expected '}'
code: 0
url: http:/127.0.0.1:2126/app/_js/jquery.jscrolpane.min.js
and if u click yes nothing appears to happen
Well gentlemen after much frustration I got the latest version installed.
Hope the flash player / adobe experts read this.
1. web site is hard to find way around- even to find this discussion page.
2. i downloaded
3. next difficulty is what extracted file installs flash player. - suggest experts provide some guidance on this.
4 tried a couple of different extracted files - a few dry gullies and it eventually worked.
5 it is not easy to navigate the adobe web site and find the above achived files.
anyway my problem is solved for time being but the run time errors still exist for other users
agin s thanks for the interest and help offered
Why didn't you just use the offline installer from my earlier direct download link?
hi Pat, I tried going to the link about 3 times and lookingg for the off line installer and could not find the link.
had trouble with the page in that every time i tried to follow a link by clicking / double clicking nothing hapened ie got no response.. maybe even though i read the page through about 3 times I could not see the link you were talking about and one link that i thought was to the offline installer failed to respond to clicks/ double clicks.
cheers
That is strange; the link should get you directly to this part of the site, with the two download links
