1. Re: My hard disk has filled up. Must ask if I can delete these.
Alan Craven Apr 13, 2013 5:52 AM (in response to AlfredKubrick9)You can delete them. Premiere will re-create those it needs next time you open each project.
You would be better to place your cache on a seaparate, fast, drive. Create an Adobe folder where you want them to be. Go to Edit, Preferences, Media tab, and there you will see two "Browse" buttons. Use each one to navigate to the Adobe folder you just created and click OK..
2. Re: My hard disk has filled up. Must ask if I can delete these.
AlfredKubrick9 Apr 13, 2013 6:04 AM (in response to Alan Craven)I see. But still, why doesn't the button do anything, and why does it keep these files around forever?
3. Re: My hard disk has filled up. Must ask if I can delete these.
Fuzzy Barsik Apr 13, 2013 6:10 AM (in response to AlfredKubrick9)Why are these files kept around at all to begin with?
See this help section on Media Cache Database.
Does the button not actually do anything?
For some reason the 'Clean' button may not delete cache files for projects other than you're currently working on. It also never deletes .ims files...
Can I safely delete them manually?
Yes. On a next start PrPro will rebuild cache files for those assets, which are currently in use in your project.
What is more, cleaning both Media Cache and Media Cache Files folders manually helps sometimes resolve some Importer's or Dynamic Link issues.
4. Re: My hard disk has filled up. Must ask if I can delete these.
John T Smith Apr 13, 2013 8:02 AM (in response to AlfredKubrick9)Drive C space http://forums.adobe.com/thread/1007934?tstart=0 indicates that you may relocate
5. Re: My hard disk has filled up. Must ask if I can delete these.
JSS1138 Apr 13, 2013 8:48 AM (in response to AlfredKubrick9)Does the button not actually do anything?
There are two sets of files here, the Media Cache, which can be quite large and take up considerable room, and the Media Cache Database, which are pretty small files. The Clean button only clears the small Database files. You have to manually delete the larger Cache files.
6. Re: My hard disk has filled up. Must ask if I can delete these.
AlfredKubrick9 Apr 13, 2013 9:25 AM (in response to JSS1138)That seems completely idiotic to me, frankly.
7. Re: My hard disk has filled up. Must ask if I can delete these.
JSS1138 Apr 13, 2013 9:32 AM (in response to AlfredKubrick9)It's not the first idiotic thing Adobe has done, and won't be the last.
8. Re: My hard disk has filled up. Must ask if I can delete these.
Fuzzy Barsik Apr 13, 2013 12:17 PM (in response to JSS1138)The Clean button only clears the small Database files.
That's not quite accurate, although quite close. Closer, than my previous statement. The 'Clean' button does sometimes delete some CFA files (which are the largest ones) in Media Cache Files folder. In particular, CFA files related to offline files in a working project. That doesn't change the whole picture though.
Paraphrasing Toomany3, the button should have been called 'Partially Clean Database Randomly'.
P.S. Nope, my previous statement was closer, since I didn't say 'does not', but rather 'may not' (delete cache files for projects other than you're currently working on).
9. Re: My hard disk has filled up. Must ask if I can delete these.
AlfredKubrick9 Apr 13, 2013 12:29 PM (in response to Fuzzy Barsik)Well, I have created a .bat file to clear the entire directory from all files. Will run that regularly. Thanks for helping me, everyone. I hope Adobe fixes these weird things.
10. Re: My hard disk has filled up. Must ask if I can delete these.
JSS1138 Apr 13, 2013 12:29 PM (in response to Fuzzy Barsik)The simple solution is to delete the Cache files manually, and use Clean for the Database. Works every time.
11. Re: My hard disk has filled up. Must ask if I can delete these.
Fuzzy Barsik Apr 13, 2013 12:49 PM (in response to JSS1138)Jim, if you were addressing me, simpler solution is to delete all files from both Media Cache and Media Cache Files folders manually and never bother of the 'Clean' button... Yes, works every time.
12. Re: My hard disk has filled up. Must ask if I can delete these.
JSS1138 Apr 13, 2013 1:26 PM (in response to Fuzzy Barsik)I'd not argue with that.
