Can some one help me where to download ..Pug in Version?
Please use the following link: http://helpx.adobe.com/flash-player/kb/find-version-flash-player.html. The link helps you to know the current version of Flash Player in your system, the latest version info, and also links to downloads.
Hope that helps.
P.S: In forums, it would be good if you can add more info on your system details and browser details so that we can provide better responses.
With regards,
Prabhu
Download and install it from the link in http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#main-pars_hea...
All your last four posts are empty!
What are you doing? You continue your empty posts. Nobody can help you if you don't post anything!
I am giving up! What is the point of your empty posts???
I've posted an answer..about my problem..maybe I did wrong way..As I told you "I open Control Panel, click on Flash Player Icon..I see Last version installed..BUT under there is another line..it says' plug in Version NOT INSTALLED....I run Windows 7 Home premium. my Desktop is Dell Pentium 4....2 gb System memory....when I am watching some soccer videos..always get message "You need Flash Player Pulg in version"...that is it
Download and run the offline installer for other browsers from the link that I posted earlier; that will install the plugin version.
Your posts are empty again!
