1. Re: How do I remove an Image from Project Start Options?
Anjaneai Srivastava Dec 18, 2012 7:14 AM (in response to lalogan111)Can you choose the Browse button, to switch to a different image (logo/graphic), import an external file as well.
The graphic option would not be applicable on Auto Play scenario, there you cna use the Preloader instead.
Anjaneai
2. Re: How do I remove an Image from Project Start Options?
JGarrou Apr 14, 2013 5:27 PM (in response to Anjaneai Srivastava)But can you actually go back to NOT having an image. I want to go back to just using the default "first screen" option that was there before I added an image.
3. Re: How do I remove an Image from Project Start Options?
Lilybiri Apr 14, 2013 11:35 PM (in response to JGarrou)Which version of CP are you using and how will you publish? I'm asking this because having the default 'first screen' is not working anymore in CP6 for publishing to pdf. For the versions where it works, just turn on AutoPlay again. The posted image will be ignored.
Lilybiri
4. Re: How do I remove an Image from Project Start Options?
JGarrou Apr 15, 2013 5:26 AM (in response to Lilybiri)Hi Lilybiri,
I am using 6.1. Interesting to know about publishing to pdf.
Thanks.
