1. Re: Previous and next article navigation question
matthew stuart Apr 17, 2013 4:49 PM (in response to matthew stuart)Don't worry, I've done it!
Turned out to be quite easy in the end.
2. Re: Previous and next article navigation question
bregent Apr 17, 2013 5:05 PM (in response to matthew stuart)Matthew, can you please post some details about your solution to assist others with similar questions?
3. Re: Previous and next article navigation question
matthew stuart Apr 17, 2013 5:23 PM (in response to bregent)I created a Previous and Next Link with the following code:
<a href="blog-detail.php?fld_bID=<?php echo $row_rs_prev['fld_bID']; ?>">Previous</a> | <a href="blog-detail.php?fld_bID=<?php echo $row_rs_next['fld_bID']; ?>">Next</a>
The above code gets its values from the three recordsets below. The first gives a URL parameter for the current record, the second uses the current URL param and the < makes sure that I am using any records below. I've also ordered by fld_bID desending to make sure the next record is that which is direct previous in the DB. The third RS uses > and is ordered by ascending to display the record that is directly after the current record.
fld_bID is key to the navigation requirements along with the SELECT queries, so I have made them bold for better visibility.
// 1st RS Allows me to go to a specific record via URL param
$colname_rs_blog = "-1";
if (isset($_GET['fld_bID'])) {
$colname_rs_blog = $_GET['fld_bID'];
mysql_select_db($database_conn_mrs, $conn_mrs);
$query_rs_blog = sprintf("SELECT * FROM tbl_blog WHERE fld_bID = %s AND fld_bSHOW = 1 ORDER BY fld_bDATE DESC", GetSQLValueString($colname_rs_blog, "int"));
$query_limit_rs_blog = sprintf("%s LIMIT %d, %d", $query_rs_blog, $startRow_rs_blog, $maxRows_rs_blog);
$rs_blog = mysql_query($query_limit_rs_blog, $conn_mrs) or die(mysql_error());
$row_rs_blog = mysql_fetch_assoc($rs_blog);
if (isset($_GET['totalRows_rs_blog'])) {
$totalRows_rs_blog = $_GET['totalRows_rs_blog'];
} else {
$all_rs_blog = mysql_query($query_rs_blog, $conn_mrs);
$totalRows_rs_blog = mysql_num_rows($all_rs_blog);
$totalPages_rs_blog = ceil($totalRows_rs_blog/$maxRows_rs_blog)-1;
// 2nd RS Moves to previous record
$colname_rs_prev = "-1";
$colname_rs_prev = $_GET['fld_bID'];
$query_rs_prev = sprintf("SELECT * FROM tbl_blog WHERE fld_bID < %s AND fld_bSHOW = 1 ORDER BY fld_bID DESC", GetSQLValueString($colname_rs_prev, "int"));
$rs_prev = mysql_query($query_rs_prev, $conn_mrs) or die(mysql_error());
$row_rs_prev = mysql_fetch_assoc($rs_prev);
$totalRows_rs_prev = mysql_num_rows($rs_prev);
// 3rd RS Moves to next record
$colname_rs_next = "-1";
$colname_rs_next = $_GET['fld_bID'];
$query_rs_next = sprintf("SELECT * FROM tbl_blog WHERE fld_bID > %s AND fld_bSHOW = 1 ORDER BY fld_bID ASC", GetSQLValueString($colname_rs_next, "int"));
$rs_next = mysql_query($query_rs_next, $conn_mrs) or die(mysql_error());
$row_rs_next = mysql_fetch_assoc($rs_next);
$totalRows_rs_next = mysql_num_rows($rs_next);
Hopefully, this makes some sense, but by all means ask if you need help.
Mat
