Seit der Umstellung von ADE1.7.2 auf 2.0 wird mein Samsung 7"Tab mit Aldiko Reader nicht mehr als neue Device erkannt. Beim anschließen per USB wird er als Speichermedium vom Laptop (Windows7) erkannt, aber nicht vom ADE.
Gibt es ein Trick?
Es bibt mehrere Garaete das bei ADE1.7.2 gut laufen; aber bei ADE2.0 gar nicht functionieren, oder nicht richtig functionieren.
Das Trick: v1.7.2 brauchen.
Wenn Sie 1.7.2 verloren haben:
Version 1.7.2, it is a little difficult to find, available on Adobe site for Windows and for Mac.
http://helpx.adobe.com/digital-editions/kb/cant-install-digital-editions.html
The forum software is sometimes corrupting the link above. There shouldn't be a blank in 'editio ns.html'. The following redirects to the same page: http://tinyurl.com/diged172
oh great, an update with bug.
-->> it's not a bug,... it's a feature <<-- 😉
The ADE2.0 update has a couple of features (IDs for multiple vendors and screen reader support); and lots of bugs.
Hoping ADE2.1 will fix some of the bugs; Abobe don't seem in the least bit interested in testing or support for ADE.
Yesterday have I the 1.7.2 installed, unfortunately works the Samsung not.
Is that a bug van ADE, Samsung 7" Tab2 of Aldiko Reader?
Just checking:
You said at first
This seems to say that originally ADE1.7.2 was working with Aldiko/tablet.
But now (after install 2.0 and reinstall 1.7.2), the exact same combination ADE1.7.2/Aldiko/tablet is no longer working?
Have I understood correctly?
As long as Aldiko and ADE are registered with the same AdobeID,
you can copy DRM .epub files from your computer to the tablet by 'sideloading'; copy using a file manager such as Windows Explorer.
This is not the most convenient way, but may help if you cannot get ADE/tablet combination working correctly.
Thanks for your reply,
maybe I have myself en fault installed.
In the next step I try the Software 2.0 to uninstall end put into operation only the 1.7.2.
