I am trying to get CF 10 installed on a Windows Server 2008 IIS 7 machine. I could not get the install to go through. Everytime I tried to bind to IIS All Sites it threw an error:
"Unable to configure IIS connector. Enable the required ISAPI options(ISAPI Extensions, ISAPI Filter, ASP.NET and CGI).
I installed as a development version and then added the serial number to see if I could trick it. It did install but when I went into the WEB SERVER CONFIGURATION tool to bind to IIS All sites, it threw the same error.
I have all the features outline in the error message installed and verified. Has anyone else had this issue. Anyone know of any fixes/workarounds. Could it be a setting in IIS that I am not aware of......any help is appreciated.
Open IIS, go to "Handler Mappings" and make sure that CGI-exe is enabled.
CGI-exe was not enabled....I did enable it and restarted the web server...IIS...but I still cannot run the WEB SERVER CONFIGURATION tool to add the IIS websites.......thanks but I have no clue what to do.
